help. light weight master cylinder #1597937
03/24/14 06:34 PM
03/24/14 06:34 PM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Ordered a light weight master cylinder from eberg about 5 years ago and it went bad over the winter. Looking to replace it. Already have the 4 to 2 mounting adapter. Searched the archives here where it said I needed a mc for a 89 Dodge Dakota. Went to the local Autozone to grab one but it did not have the recessed part in the back that retains the brake pushrod, nor did it come with the new rubber piece that goes on the rod itself.
Help, need this ready this weekend. I guess I could get a stock one for it if it came down to it but I'd rather not.
Re: help. light weight master cylinder [Re: POZEST] #1597938
03/24/14 07:37 PM
03/24/14 07:37 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Take a look at one from a K car. If I remember correctly that might work.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: help. light weight master cylinder [Re: Eric] #1597939
03/24/14 08:40 PM
03/24/14 08:40 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I think the one you want is the 77-78 Volare. If you can't find one, come and get mine.
Looks like this one.
http://www.summitracing.com/parts/str-b3360/overview/
Re: help. light weight master cylinder [Re: cgall] #1597940
03/24/14 08:44 PM
03/24/14 08:44 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
85 dodge diplomat.
Re: help. light weight master cylinder [Re: cgall] #1597941
03/24/14 09:08 PM
03/24/14 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If this is the size you need it says it will ship today..
you would have it in a day easily
Re: help. light weight master cylinder [Re: MR_P_BODY] #1597942
03/24/14 09:39 PM
03/24/14 09:39 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
hey mike thanks for the info i asked you about. but if you have to order one how about this one??
http://www.doctordiff.com/aluminum-master-cylinder-kit.html
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: help. light weight master cylinder [Re: mopar65] #1597943
03/24/14 09:51 PM
03/24/14 09:51 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Here is reman unit for 78 Volare/Aspen, $28 on rockauto.
http://www.cardone.com/Products/Product-Detail?productId=101821&p=rock
Re: help. light weight master cylinder [Re: cgall] #1597944
03/24/14 09:56 PM
03/24/14 09:56 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Mine was off a mid to late 80s half ton truck IIRC
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: help. light weight master cylinder [Re: cgall] #1597945
03/24/14 10:00 PM
03/24/14 10:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will guarantee he gets the Summit one before the
others... but if he is close enough he can pick it up..
if he orders it early enough in the morning(6-7 am)
he will have it that day... at least I do and he is
a lot closer
Re: help. light weight master cylinder [Re: POZEST] #1597946
03/24/14 11:04 PM
03/24/14 11:04 PM
AndyF Offline
AndyF  Offline
www.doctordiff.com is the place for master cylinders and related Mopar brake stuff.
Re: help. light weight master cylinder [Re: AndyF] #1597947
03/25/14 11:47 AM
03/25/14 11:47 AM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Just got off the phone with smythe automotive. They say theirs has a machined step in it for the retainer. 89 Dakota 15/16 bore. Just need to find a new rubber piece. Thanks for the replies.
Re: help. light weight master cylinder [Re: POZEST] #1597948
03/25/14 11:12 PM
03/25/14 11:12 PM
S.W. Ohio
clyde Offline
clyde  Offline
S.W. Ohio
Rubber piece? What rubber piece?
Re: help. light weight master cylinder [Re: clyde] #1597949
03/26/14 02:59 AM
03/26/14 02:59 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Mancini's carry that little rubber piece. I know of no other place. Surprising because its junk once you pull the pushrod out!
But some guys on here have used thin rubber or vinyl hose. All it does is stop the pushrod from wobbling around in the cup.
http://chucker54.stores.yahoo.net/brpubu.html
Re: help. light weight master cylinder [Re: Stanton] #1597950
03/26/14 12:07 PM
03/26/14 12:07 PM
AndyF Offline
AndyF  Offline
www.doctordiff.com has everything that you need including the rubber grommet.
Re: help. light weight master cylinder [Re: Stanton] #1597951
03/26/14 12:17 PM
03/26/14 12:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If thats the piece I think it is.. it looks like it..
but that is to keep the push rod in the master.. it
can be a real PITA to get it out... it snaps in place
with the push rod... was for safety so the rod couldnt
slip out
Re: help. light weight master cylinder [Re: MR_P_BODY] #1597952
03/28/14 12:23 AM
03/28/14 12:23 AM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Ended up with a mc for a 85 Dodge diplomat, seemed like the same bore as a stock demon. Thanks prochamp for running all the numbers and rbduster for the actual sale. Mc didn't come with the retaining bushing so it was made with a piece of vacuum line. Feels good and solid. Thanks for the ideas fellas.
Re: help. light weight master cylinder [Re: POZEST] #1597953
03/28/14 07:49 AM
03/28/14 07:49 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Was it aluminum or cast iron?
Re: help. light weight master cylinder [Re: Scamp408] #1597954
03/29/14 01:54 AM
03/29/14 01:54 AM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Aluminum.
Re: help. light weight master cylinder [Re: POZEST] #1597955
03/31/14 03:46 PM
03/31/14 03:46 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just get a Wilwood,Aerospace or Strange kit,they have everything you need.Wilwood kit-260-4894,Aerospace-MBC7993,Strange-3359 or 3360.Wilwood and Strange are aprox,$100 and you get fittings,rod and boots,rubber retainer and a couple of plate adapter/spacers.
