Main bearings for Big Block
#1597687
03/24/14 11:56 AM
03/24/14 11:56 AM
Posts: 2,653 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm freshening up a buddy's 528 bracket motor with Mopar size journals. Well, the crank has between .001 and .0018 of wear on the rod journals. Does anybody make rod bearings with less clearance? Thanks
2011 Drag Pak Challenger
Re: Main bearings for Big Block
[Re: rickseeman]
#1597688
03/24/14 12:09 PM
03/24/14 12:09 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Yes, if its still a Mopar rod journal, you'll need a Clvite CB527HND001. You can also try some coated bearing, which reduce the vertical clearance as well, but coating are really meant to be sacrificial over time, and the clearance will increase. If its a motr that gets freshened often, maybe not so bad. I would think though, the first bearing will do it.
RIP Monte Smith
[Re: rickseeman]
#1597689
03/24/14 12:23 PM
03/24/14 12:23 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
What is your total oil clearence?
[Re: B G Racing]
#1597690
03/24/14 12:28 PM
03/24/14 12:28 PM
rickseeman
Stuttgart, Arkansas
Between .004 and .0048. Ain't pretty. My buddy says if he has to buy a new crank he won't be able to afford to eat. I told him he could afford to lose a few pounds anyway.
[Re: CompWedgeEngines]
#1597691
03/24/14 01:43 PM
03/24/14 01:43 PM
rickseeman
Stuttgart, Arkansas
Thanks, I think I found some of the Clevites.
