Rear Housing Math Wizards #1597561
03/23/14 07:56 PM
03/23/14 07:56 PM
Colorado
funnycar65 Offline OP
Colorado
My total rearend with is 51in.wheel mounting flange to flange,what should my housing width be,bearing flange to flange?
Re: Rear Housing Math Wizards [Re: funnycar65] #1597562
03/23/14 08:03 PM
03/23/14 08:03 PM
Which rear end housing, brand and size, and which axles and brakes are you wanting to use?
Re: Rear Housing Math Wizards [Re: Cab_Burge] #1597563
03/23/14 08:08 PM
03/23/14 08:08 PM
Colorado
Colorado
8 3/4 stock axles sorry should have put that in my post.I my math is correct it should be 47 15/16 flange to flange
Re: Rear Housing Math Wizards [Re: funnycar65] #1597564
03/23/14 08:22 PM
03/23/14 08:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
To get the housing width subtract 5.05" from the axle flange width then factor in the thickness of the drums or discs that mount on the axle flange.
Re: Rear Housing Math Wizards [Re: funnycar65] #1597565
03/24/14 12:12 AM
03/24/14 12:12 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
2 1/2" axle stand-off per side + whatever the thickness of the drum/rotor.
With drum brakes I would say 45 3/4" bearing flange to bearing flange.
Re: Rear Housing Math Wizards [Re: Forest] #1597566
03/24/14 12:40 AM
03/24/14 12:40 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I got 45.7 which is real close
Re: Rear Housing Math Wizards [Re: RobX4406] #1597567
03/24/14 09:29 PM
03/24/14 09:29 PM
Colorado
Colorado
thanks guys!
Re: Rear Housing Math Wizards [Re: RobX4406] #1597568
03/27/14 09:59 PM
03/27/14 09:59 PM
Colorado
Colorado
at 45 3/4 what is the lenght of the axles?
Re: Rear Housing Math Wizards [Re: funnycar65] #1597569
03/27/14 10:09 PM
03/27/14 10:09 PM
RobX4406 Offline
RobX4406  Offline
24.65"
