Re: Rear Housing Math Wizards
[Re: funnycar65]
#1597562
03/23/14 08:03 PM
03/23/14 08:03 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
Which rear end housing, brand and size, and which axles and brakes are you wanting to use?
[Re: funnycar65]
#1597564
03/23/14 08:22 PM
03/23/14 08:22 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To get the housing width subtract 5.05" from the axle flange width then factor in the thickness of the drums or discs that mount on the axle flange.
[Re: funnycar65]
#1597565
03/24/14 12:12 AM
03/24/14 12:12 AM
Posts: 916 SE Washington
Forest
SE Washington
My total rearend with is 51in.wheel mounting flange to flange,what should my housing width be,bearing flange to flange?
2 1/2" axle stand-off per side + whatever the thickness of the drum/rotor.
With drum brakes I would say 45 3/4" bearing flange to bearing flange.
[Re: Forest]
#1597566
03/24/14 12:40 AM
03/24/14 12:40 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
I got 45.7 which is real close
