What oil pump should I get for my 383 #1596207
03/21/14 03:42 PM
03/21/14 03:42 PM
Spokane Washington
P
pro-streeter Offline OP
P
Spokane Washington
I am about to purchase a new oil pump for my 1969 Road Runner 383 auto with AC. The car is stock so I am not looking for a higher performance pump, unless it is recommended. As I understand the HP pumps are thicker, does that cause any problems?
Thanks for any help
Re: What oil pump should I get for my 383 [Re: pro-streeter] #1596208
03/21/14 03:53 PM
03/21/14 03:53 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
I've run a Melling hv oil pump on all the big blocks I've had.... 2 400's, 2 440's and one 383.....without any problems.....
Re: What oil pump should I get for my 383 [Re: pro-streeter] #1596209
03/21/14 03:56 PM
03/21/14 03:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I run standard volume pumps, that's all that's needed. That's all you need.
Re: What oil pump should I get for my 383 [Re: Challenger 1] #1596210
03/21/14 04:05 PM
03/21/14 04:05 PM
dogdays Offline
dogdays  Offline
Standard pump is enough.
R.
Re: What oil pump should I get for my 383 [Re: Challenger 1] #1596211
03/21/14 04:06 PM
03/21/14 04:06 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Standard pump with stock pan.High pressure is ok not HV
Leave the gun.......take the Cannoli's....Mike
Re: What oil pump should I get for my 383 [Re: pro-streeter] #1596212
03/21/14 04:34 PM
03/21/14 04:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Standard volume pump is fine , if you go to a HV pump you need longer bolts .
Re: What oil pump should I get for my 383 [Re: pro-streeter] #1596213
03/21/14 05:13 PM
03/21/14 05:13 PM
A std vol/std psi sealed power or other parts house pump is fine. I would take your feeler gauges & check the several clearances (easy to do/assembly line mistakes do happen). I'd use a normal wt of oil & see what you end up with for psi & 8lbs per 1K RPM is fine for a DD & even a low # at idle is OK IF it jumps up immediately when you get on it
Re: What oil pump should I get for my 383 [Re: pro-streeter] #1596214
03/21/14 05:33 PM
03/21/14 05:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is no set answer to this question, if the standard volume pump produces acceptable pressure throughout the rpm/temperature it's obviously OK.
But if, due to loose clearances, the pressure drops off with temperature, a HV pump is called for. Luckily, on a BB it's changeable in situ.
