Re: What oil pump should I get for my 383
[Re: Challenger 1]
#1596211
03/21/14 04:06 PM
03/21/14 04:06 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Standard pump with stock pan.High pressure is ok not HV
Leave the gun.......take the Cannoli's....Mike
[Re: pro-streeter]
#1596213
03/21/14 05:13 PM
03/21/14 05:13 PM
RapidRobert
A std vol/std psi sealed power or other parts house pump is fine. I would take your feeler gauges & check the several clearances (easy to do/assembly line mistakes do happen). I'd use a normal wt of oil & see what you end up with for psi & 8lbs per 1K RPM is fine for a DD & even a low # at idle is OK IF it jumps up immediately when you get on it
[Re: pro-streeter]
#1596214
03/21/14 05:33 PM
03/21/14 05:33 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There is no set answer to this question, if the standard volume pump produces acceptable pressure throughout the rpm/temperature it's obviously OK.
But if, due to loose clearances, the pressure drops off with temperature, a HV pump is called for. Luckily, on a BB it's changeable in situ.
