Afco shock valving for rear #1593813
03/16/14 01:28 PM
03/16/14 01:28 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I can get a good deal on a pair of afco rebuildable/revalvable shocks, but the valving is 1-9. I'm thinking the valving is too stiff on rebound and possibly too soft on compression. I'm curious what others run for valving on this type of shock.
Mine is a leaf spring(SS) car.
Yeah, it's got a smallblock.
Re: Afco shock valving for rear [Re: 340B5] #1593814
03/16/14 02:09 PM
03/16/14 02:09 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
i tryed running afco in the rear just changed to santhuff
Re: Afco shock valving for rear [Re: 340B5] #1593815
03/16/14 02:22 PM
03/16/14 02:22 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
There are many different valving options out there. Which version is it, is it a double adj. or single adj.? What tires are you using, how much power etc...
Pretty hard to get a good solid answer when you don't provide much info about what you're trying to do with them.
Re: Afco shock valving for rear [Re: 340B5] #1593816
03/16/14 02:25 PM
03/16/14 02:25 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
are these shocks used or new? Are they for Drag racing or circle track? Are they Double adjustable or single? Do you have a part #?
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Afco shock valving for rear [Re: 440W8 Duster] #1593817
03/16/14 03:12 PM
03/16/14 03:12 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
These are a "fixed" valve, but rebuildable and re-valveable. A set of rancho adjustables would do the job as the car is 500hp, but I have clearance issues and would prefer a smaller body and also a softer compression.
Re: Afco shock valving for rear [Re: 340B5] #1593818
03/16/14 03:39 PM
03/16/14 03:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself.... I would pass... one set of valving wont
cover all conditions
Re: Afco shock valving for rear [Re: MR_P_BODY] #1593819
03/16/14 04:25 PM
03/16/14 04:25 PM
San Antonio,TX
San Antonio,TX
I would buy a set of DA Afco shock if it were me.
70 Duster W8 motor.
@3170 lbs.
Re: Afco shock valving for rear [Re: 440W8 Duster] #1593820
03/16/14 11:27 PM
03/16/14 11:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
At 500 hp the rancho is more then enough shock. If you need a small body you could get a strange single adjustable shock very reasonable.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Afco shock valving for rear [Re: 1967dartgt] #1593821
03/16/14 11:37 PM
03/16/14 11:37 PM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
I am retireing my 5 way Rancho's in favor of a set of Vi-king DA shocks.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Afco shock valving for rear [Re: hemi-itis] #1593822
03/16/14 11:44 PM
03/16/14 11:44 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What type of rear suspension?
Re: Afco shock valving for rear [Re: 1967dartgt] #1593823
03/16/14 11:52 PM
03/16/14 11:52 PM
Caltrac Split mono and bar.
Re: Afco shock valving for rear [Re: hemi-itis] #1593824
03/16/14 11:59 PM
03/16/14 11:59 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Good luck I don't feel that the shock will work for you. You make to much power. Let us know how it works out, hopefully the slicks can handle it. I hope I am wrong.
Re: Afco shock valving for rear [Re: 1967dartgt] #1593825
03/17/14 12:20 AM
03/17/14 12:20 AM
They seem to think their rear shock with the aggressive valveing will handle it We'll see
Re: Afco shock valving for rear [Re: hemi-itis] #1593826
03/27/14 04:25 PM
03/27/14 04:25 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Just pulled the trigger on Viking shocks. I'd be curious as to whether others like theirs.
Re: Afco shock valving for rear [Re: 340B5] #1593827
03/27/14 07:11 PM
03/27/14 07:11 PM
Dyno1 Offline
Dyno1  Offline
If you want a drag racing shock you must go with the better quality shocks available (Afco, Penske, Koni, JRI). the QA1's Viking, Jeg's, etc are throw away shocks if they leak or do not work, it cost more to rebuild them than they are worth.
Re: Afco shock valving for rear [Re: Dyno1] #1593828
03/28/14 01:20 AM
03/28/14 01:20 AM
Vi-king feels their rear shock with the aggressive valving option will compete with Santhuff shock.He said if they don't work for me they would take them back
Re: Afco shock valving for rear [Re: one bad fish] #1593829
03/28/14 12:03 PM
03/28/14 12:03 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Should have sent them to Mark he would have fixed you up for less then the cost of one santuff. Petey uses Mark in the x275 car.
