Afco shock valving for rear
#1593813
03/16/14 01:28 PM
03/16/14 01:28 PM
Posts: 1,532 off the grid
340B5
off the grid
I can get a good deal on a pair of afco rebuildable/revalvable shocks, but the valving is 1-9. I'm thinking the valving is too stiff on rebound and possibly too soft on compression. I'm curious what others run for valving on this type of shock.
Mine is a leaf spring(SS) car.
Yeah, it's got a smallblock.
Re: Afco shock valving for rear
[Re: 340B5]
#1593816
03/16/14 02:25 PM
03/16/14 02:25 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
are these shocks used or new? Are they for Drag racing or circle track? Are they Double adjustable or single? Do you have a part #?
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 440W8 Duster]
#1593817
03/16/14 03:12 PM
03/16/14 03:12 PM
340B5
off the grid
These are a "fixed" valve, but rebuildable and re-valveable. A set of rancho adjustables would do the job as the car is 500hp, but I have clearance issues and would prefer a smaller body and also a softer compression.
[Re: 340B5]
#1593818
03/16/14 03:39 PM
03/16/14 03:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Myself.... I would pass... one set of valving wont cover all conditions
[Re: MR_P_BODY]
#1593819
03/16/14 04:25 PM
03/16/14 04:25 PM
440W8 Duster
San Antonio,TX
I would buy a set of DA Afco shock if it were me.
[Re: hemi-itis]
#1593826
03/27/14 04:25 PM
03/27/14 04:25 PM
340B5
off the grid
Just pulled the trigger on Viking shocks. I'd be curious as to whether others like theirs.
[Re: Dyno1]
#1593828
03/28/14 01:20 AM
03/28/14 01:20 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
If you want a drag racing shock you must go with the better quality shocks available (Afco, Penske, Koni, JRI). the QA1's Viking, Jeg's, etc are throw away shocks if they leak or do not work, it cost more to rebuild them than they are worth.
Vi-king feels their rear shock with the aggressive valving option will compete with Santhuff shock.He said if they don't work for me they would take them back
