Camper 440?? #1592704
03/14/14 05:15 AM
03/14/14 05:15 AM
Iowa
76dodgeboy Offline OP
Iowa
Theres a guy with a 440 claimed to be a Factory Propane Motor that had extra webbing and a steel crank. Claims it weighs 200lbs mot than a normal 440. Any truth to this?
Re: Camper 440?? [Re: 76dodgeboy] #1592705
03/14/14 03:13 PM
03/14/14 03:13 PM
I've never heard of a 440 motor that Mopar made special for Propane use International Harvester did Propane has a lot less energy(BTU) per liquid gallon than the other commercial fuels out there, it does not make the power needed to have to spend money reinforcing the block, me thinks your guy is blowing smooke about this Maybe he is just ignorant and repeating something he was told BTW, Mopar, Dodge division, did make 440-3 motors for motorhomes and Dodge may have used some of them in the bigger trucks, I have had two of those motors, they do not weigh anymore than a standard complete 440 does The 361 and 413 industrial motors may have weighed a little more than the standard productions motor but not 200 lbs more Mopar did add additional reinforcing ribs on the outsides of all the passenger car 440 blocks built and used in or after 1969, I think it was
Re: Camper 440?? [Re: 76dodgeboy] #1592706
03/14/14 03:18 PM
03/14/14 03:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
200 lbs. heavier?
Re: Camper 440?? [Re: John_Kunkel] #1592707
03/14/14 03:36 PM
03/14/14 03:36 PM
Southeast Wisconsin
Sunroof_Cuda Offline
Southeast Wisconsin
Propane X --- a 1969 Charger ---- campaigned in the day (1969 or 1970)to demonstrate the value of propane as motor fuel. The articles I read back then discussed the fuel delivery changes, not changes to the block, etc.
Re: Camper 440?? [Re: Sunroof_Cuda] #1592708
03/14/14 03:45 PM
03/14/14 03:45 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
I have seen my share of BB's in MH's ....and I have never seen a diff between a regular 440 block and one that is in a MH. The 413 now is a diff story.
Re: Camper 440?? [Re: John_Kunkel] #1592709
03/14/14 06:10 PM
03/14/14 06:10 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
200 lbs. heavier?
When you consider a 440 bare block weighs roughly 225 pounds, this one is supposed to weigh almost twice as much? Umm, I don't think so.
Re: Camper 440?? [Re: vdriver] #1592710
03/14/14 11:33 PM
03/14/14 11:33 PM
Iowa
Iowa
He claims to have done his research and says its legitimately. I mentioned the Propane was probably an aftermarket add on just like the Turbo kits offered. I'll see if he can get me pics
Re: Camper 440?? [Re: 76dodgeboy] #1592711
03/15/14 12:38 AM
03/15/14 12:38 AM
My new unmachnied World Products cast iron race block with 4 4 bolt mains weighs 320 lbs, the Koleno high nickel block with all five main bearings having 4 bolt mains weigh just about the same as the World block, maybe 5 to 10 lbs more A stock 440 block weighs bewteen 205 to 220 lbs depening on the machine work done to it and how much gunk is in the water passages and what year the block is, trust me on that I've weigh a bunch of the 440 and 400 blcoks looking of the best ones to use as a race motor build, the new aftermarket blocks are the best choice Me thinks he is trying to sell you what he has
Re: Camper 440?? [Re: Cab_Burge] #1592712
03/15/14 02:06 AM
03/15/14 02:06 AM
Iowa
Iowa
He was actually asking what it would be worth. I stated they didnt have propane specific than he laid it on with his research that I asked for a link for. It was apparently a few years ago so he had to find it. I mainly want to Further my knoledge on Mopars. Thanks everyone
Oh When did they stop the steel crank production? 69 wasnt it? He said its a 70s motor
Re: Camper 440?? [Re: 76dodgeboy] #1592713
03/15/14 03:42 AM
03/15/14 03:42 AM
I had a 1973 440-3 motorhome motor that had a forged steel crank with 6 pak rods Mopar started using the cast steel cranks in some of the automatic cars in 1972 or 1973
Re: Camper 440?? [Re: Cab_Burge] #1592714
03/15/14 12:31 PM
03/15/14 12:31 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Cab I had the same motor When flipped upside down one would swear it was a 413 Industrial like the others it sat with because of the rotating assembly
Re: Camper 440?? [Re: 76dodgeboy] #1592715
03/16/14 01:57 AM
03/16/14 01:57 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I believe there were some motorhome 440's that used different heads that were quite a bit bigger than standard 440 heads and a different water pump.. I believe they had ports on the heads that the water pump bolted to.. it has been about since I seen this engine but IIRC it was a 440 from a 73 motor home and the guy wanted big bucks for it because he thought it was something special.
Re: Camper 440?? [Re: rumblebee4232] #1592716
03/16/14 02:39 AM
03/16/14 02:39 AM
Iowa
Iowa
Yeah Ive seen one or two like that. Smallblocks were the same. Was specifically for better cooling
Re: Camper 440?? [Re: rumblebee4232] #1592717
03/16/14 03:48 AM
03/16/14 03:48 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
That's the industrial 413. Very common in motorhomes up until the early 70's.
Re: Camper 440?? [Re: rumblebee4232] #1592718
03/16/14 04:57 AM
03/16/14 04:57 AM
As already pointed out by Viperblue, some of the 1973 Class A motorhomes where built on 1972 chassis with the industrial 413-3 motors, not the 440 or 440-3 motors. The 440 motorhome motors used the standard 440 head castings with better valves and some(the 440-3)had additional coolant passages around the exhaust ports and seats
