Re: Camper 440??
[Re: John_Kunkel]
#1592709
03/14/14 06:10 PM
03/14/14 06:10 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
200 lbs. heavier?
When you consider a 440 bare block weighs roughly 225 pounds, this one is supposed to weigh almost twice as much? Umm, I don't think so.
Re: Camper 440??
[Re: Cab_Burge]
#1592712
03/15/14 02:06 AM
03/15/14 02:06 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
He was actually asking what it would be worth. I stated they didnt have propane specific than he laid it on with his research that I asked for a link for. It was apparently a few years ago so he had to find it. I mainly want to Further my knoledge on Mopars. Thanks everyone Oh When did they stop the steel crank production? 69 wasnt it? He said its a 70s motor
Re: Camper 440??
[Re: 76dodgeboy]
#1592713
03/15/14 03:42 AM
03/15/14 03:42 AM
Posts: 43,274 Bend,OR USA
Cab_Burge
Re: Camper 440??
[Re: Cab_Burge]
#1592714
03/15/14 12:31 PM
03/15/14 12:31 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
I had a 1973 440-3 motorhome motor that had a forged steel crank with 6 pak rods Mopar started using the cast steel cranks in some of the automatic cars in 1972 or 1973
Cab I had the same motor When flipped upside down one would swear it was a 413 Industrial like the others it sat with because of the rotating assembly
Re: Camper 440??
[Re: rumblebee4232]
#1592717
03/16/14 03:48 AM
03/16/14 03:48 AM
vdriver
Leucadia, Ca.
I believe there were some motorhome 440's that used different heads that were quite a bit bigger than standard 440 heads and a different water pump.. I believe they had ports on the heads that the water pump bolted to.. it has been about since I seen this engine but IIRC it was a 440 from a 73 motor home and the guy wanted big bucks for it because he thought it was something special.
That's the industrial 413. Very common in motorhomes up until the early 70's.
