Page 1 of 4 1 2 3 4
Erson Cams Quality Discussion #1592415
03/13/14 05:11 PM
03/13/14 05:11 PM
Louisville, KY USA
E
ErsonCamShop Offline OP
E
Louisville, KY USA
Looking for feedback on Erson Cams. I'm hoping to get some insight into your experiences with the quality, precision, time it takes to receive a cam from Erson, and contacting sales and technical assistance. Good, bad, or indifferent.
Re: Erson Cams Quality Discussion [Re: ErsonCamShop] #1592416
03/14/14 01:12 AM
03/14/14 01:12 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
They still make cams? They make them for something other than a small block Chevy ?
Re: Erson Cams Quality Discussion [Re: ErsonCamShop] #1592417
03/14/14 01:54 AM
03/14/14 01:54 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Do they still have the old grinds as well? The Super High Flow II was a great hydraulic for a stock inch Street Hemi.
Sheldon
Re: Erson Cams Quality Discussion [Re: RUNCHARGER] #1592418
03/14/14 04:03 AM
03/14/14 04:03 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Friend got a Erson High Flow from Summit for his wedge - close to 300 duration and 475-480 lift
I don't know if it has the same specs as the old days or if it's a modern grind
Seems like alot of duration compared to lift myself - but he seems to like it
Re: Erson Cams Quality Discussion [Re: Kern Dog] #1592419
03/14/14 10:37 AM
03/14/14 10:37 AM
Louisville, KY USA
E
E
Louisville, KY USA
Yes, we're still making cams, and yes we still have all of Sig Erson's original profiles. I took the manufacturing facility over in October of 2011 and I'm striving to make the best camshaft product on the market. We do have a few more modern, aggressive profiles with higher lifts. Trying to cover the whole market. We'd be glad to custom grind you a camshaft. Our custom turnaround times are generally within 24 hours. This is the manufacturing facility, not salesmen. We're looking for feedback on what the market is asking for and what will bring our customers the highest quality product out.
Russ
Re: Erson Cams Quality Discussion [Re: RUNCHARGER] #1592420
03/14/14 10:39 AM
03/14/14 10:39 AM
Louisville, KY USA
E
E
Louisville, KY USA
Sheldon
Yes, we still make all of Sig's original Mopar and Hemi cams. We have all of the original profiles. If you have any of your favorites that you would like, just let us know. If you have any other questions feel free to ask.
Russ
Re: Erson Cams Quality Discussion [Re: ErsonCamShop] #1592421
03/14/14 12:02 PM
03/14/14 12:02 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
There's a lot of discussion (here and other forums) about the poor quality of aftermarket cams/lifters on the shelves today. I don't run an Erson (or any other aftermarket) cam, but when I read your post, the first question that popped into my head was: I wonder what, if anything, Erson is doing better than everyone else to prevent this? Also, do you manufacture your own lifters, or do you source them from elsewhere?
Re: Erson Cams Quality Discussion [Re: Fat_Mike] #1592422
03/14/14 04:22 PM
03/14/14 04:22 PM
Louisville, KY USA
E
E
Louisville, KY USA
We don't manufacture our on lifters at this time. Believe me, I wish that we did. But on the cam side of things, we do run every cam we grind across the Campro machine to make sure that it specs out to be exactly what it is supposed to be. Where a lot of your larger companies check one out of twenty or one out of fifty, we test every cam. We also check the taper on all of our flat tappets to make sure that it's at its maximum angle to work with the flat tappet lifters that the end user is forced to use. We are striving to make the best cam product on the market, so we welcome any feedback that will help us better what we do.
Russ
Re: Erson Cams Quality Discussion [Re: ErsonCamShop] #1592423
03/14/14 04:32 PM
03/14/14 04:32 PM
USA
b54406barrel Offline
USA
Ran your old 306 (# I think?) in a few sideoilers back in the day. Great performing cam! Where is a link to your mopar cams, please?
Re: Erson Cams Quality Discussion [Re: b54406barrel] #1592424
03/14/14 05:12 PM
03/14/14 05:12 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Hello Russ !!! I know you guys inspect every cam I've seen it during my visits for Radiac Abrasives. Tell Troy and the guys I said hello.
MLR426 Martin Wimberly
Re: Erson Cams Quality Discussion [Re: MLR426] #1592425
03/14/14 07:12 PM
03/14/14 07:12 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
How about posting a sample catalog of your Mopar grinds???
I had my machine shop check into one of your grinds a year or so ago. It appeared to be a "modern" grind, by the adv, .050, .200 and lift compared to a comparable Comp "modern" lobe.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Erson Cams Quality Discussion [Re: Von] #1592426
03/14/14 10:08 PM
03/14/14 10:08 PM
I work part time at a shop that uses lots of Ersons--First Class quality--EXCELLENT tech help and turn around time --they are as good as any grinder out there. All the BS about "modern" grinds always chaps me as an engine builder--customers will take months and spend weeks to select the PERFECT latest hi tech Whamodynoe 9000 camshaft--then almost always they could have made a better choice and do some other thing that defies logic and hurts the build way more than the less than perfect cam would--The cold hard truth is that most all "modern" grinds are MAXING out usable lifter area--a luxury Mopar had--as in had at one time but now these grinds beat the heck out of the valve train--have used up the extra lifter diameter "safety zone" that Mopar has always enjoyed--and for WHAT??? A Few extra HP that the Computer "says" will be there??? So what if it is 10 extra HP??? Who cares?? Now you are beating up the valve train--having to use crazy spring pressure to control this stupid computer designed ( and almost always UN-TESTED) junk--killing lifters--Oh Boy!!! I gots me an extra HP--Yahoo!!!!
Erson is great! I know shops that can build more HP with a $52 big Summit cam than a $400 custom because they know what they are doing with the other 95% of the build.
Ok go back to wasting your nights picking that perfect dream cam that will make your engine perfect. I will build another with the ole Scummit special that will melt some more tires and make another customer happy and I will probably send it out the door with way less spring pressure than you would approve of yet it will still turn ( and control) all of the usable RPM the cam can muster.
I guess I should start using Comps newest roller cams that Now require ( per their advice) near 1000 lbs open pressure to control--oh wait ...my lifter wheels just passed into the oil pan! But..that thing made some extra HP because the computer said so
Re: Erson Cams Quality Discussion [Re: ErsonCamShop] #1592427
03/14/14 10:08 PM
03/14/14 10:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Are your cams chevy profiles on a Mopar stick?
Re: Erson Cams Quality Discussion [Re: 71birdJ68] #1592428
03/14/14 10:13 PM
03/14/14 10:13 PM
Ok Ok I just came off a 16 hour day and am a little ragged--but Erson is a great cam seller and yes I have made awesome HP in a Mopar with "ole Chevy lobes " on Mopar stick--everyone used to
Yes the latest will net you a few but it is at a Big price IMO
Re: Erson Cams Quality Discussion [Re: 71birdJ68] #1592429
03/14/14 10:16 PM
03/14/14 10:16 PM
Northern MN
cedarmachine Offline
Northern MN
I use Erson cams more than any other. As Russ said, they have many new profiles, as well as the time proven designs. If you speak directly to Erik at Erson, he can help with the best profile for your application.
I will say, the new 3 piece core, billet roller cores are the best. They have a cast distributor gear that is replaceable. It does not require a bronze gear on the distributor either. These cores are made by Callies and the quality is outrageous. I don't know if the availability covers all makes yet, however.
I never wait longer than a few days for a custom grind, right to my door.
Re: Erson Cams Quality Discussion [Re: cedarmachine] #1592430
03/17/14 01:53 AM
03/17/14 01:53 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
At one time Erson did a group buy with www.slantsix.org I never bought one. I wonder about the quality of blanks for the slant. Regrinding a stock cam could be an option. I'll post a link to the group over there.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Erson Cams Quality Discussion [Re: Rug_Trucker] #1592431
03/17/14 02:15 AM
03/17/14 02:15 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'd also like to see the latest catalog and cam profiles for Mopars. Can't find anything on the web.
Re: Erson Cams Quality Discussion [Re: Exit1965] #1592432
03/17/14 04:47 AM
03/17/14 04:47 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
I run a Erson in a 383 that has been in a Challenger, Dart Swinger & now a 56 Plymouth. 906 heads, Holley SD intake & TQ carb. The engine has, and continues, to perform flawlessly. Great street manners, nice thump at idle & plenty of giddy-up when the traffic light goes green. I'm very happy with what I have.
My reference page is a worn xerox copy of the Mopar section of a 1984 Erson catalog from a Super Shops parts counter.
Re: Erson Cams Quality Discussion [Re: ProStock1320] #1592433
03/17/14 05:10 AM
03/17/14 05:10 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I ran a Erson 270 grind in a slant 6 for years. I would love to have another, along with a 280! With a 270 cam, 3.55 gear, 833od, mildly ported head with big stainless valves, a super six intake, 2.5" exhaust, and a mopar electronic distributor using a gm hei module, my 84 swb truck would pull a proven 25-27 mpg at 70 mph, if not bucking a wind over 15 mph.
I ran this cam for over 75000 miles with no issues whatsoever. A lot of people thought it had a healthy small block in it. It sounded really sweet! I was never kind to that engine.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Erson Cams Quality Discussion [Re: old_goat] #1592434
03/17/14 11:09 AM
03/17/14 11:09 AM
Louisville, KY USA
E
E
Louisville, KY USA
Our web designer is working on getting a PDF on our website that will contain all of our Chrysler grinds. If anyone would like us to mail them a catalog that has all the Chrysler A and B cams in it and a list of our masters for our profiles, we'll be glad to send them one. Just PM us requesting it with your personal email address and home address for the catalog. The file is too large to post in this forum. As far as our profiles being Chevy profiles on a Chrysler stick, we have profiles that are meant to be on 840 tappets, 870 tappets and 900 tappets. Every cam company uses multiple lobes for multiple applications. It's just a matter of how aggressive you want your ramp profile to be and how hard you want to beat up your valve train for which profile we put on your cam. If you get our catalog and look through our lobes you can pick out the profiles you want on your Chrysler stick. If anyone has any other questions or anymore feedback, we welcome it. If anyone is ever in our area, I would gladly give you a tour. You can ask Martin from Radiac. I'll gladly show you around and proudly show you the quality and craftsmanship that we grind into every Erson cam.
Russ
Page 1 of 4 1 2 3 4
