torsion bar install ? #159104
11/30/08 11:35 AM
11/30/08 11:35 AM
rochester ny
challengerx Offline OP
rochester ny
Ok, I have the K frame bolted to the car with all susp parts together except the uca are not connected to the spindles. I have the t bars through the crossmember. The lca are hanging all the way down. I put the t bars in the lca sockets and that went fine but now I can't lift the lca to meet up with the ball joint in the uca. Do I have to have the lca raised a little and if you do how do you make it even side to side. Thanks
Re: torsion bar install ? [Re: challengerx] #159105
11/30/08 11:55 AM
11/30/08 11:55 AM
Summerfield,FLorida
mousefink Offline
mousefink  Offline
Summerfield,FLorida
installing teh torsion bars should be the very last step you do when reassmbling the suspension.if teh torsion bars are in the lca's,it makes it hard to move them into position.becauseyou are trying to move the contorl arms against the torsion bar tension,even with the adjusting bolts backed off.
67 Charger 383 6 pak 68 Charger 383 Magnum 73 Charger 383 72 Coronet R/T 4 speed wagon 98 Dodge Ram
Re: torsion bar install ? [Re: mousefink] #159106
11/30/08 12:08 PM
11/30/08 12:08 PM
rochester ny
rochester ny
ok thanks I will connect the uca to the spindle and give it a try. Also anything I need to know about connecting the ball joint to the spindle, it looks like the ball joint boot has some type of notch on the bottom is this there for a reason. Can you tell I have never done this before.
Re: torsion bar install ? [Re: challengerx] #159107
11/30/08 02:00 PM
11/30/08 02:00 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i think the notch is an escape route for any excess grease to squeez out from. make sure it faces AWAY from the brakes. and be sure the t-bar adjuster bolt is backed all the way out and the uca bump stop is removed before inserting the t-bar.
Re: torsion bar install ? [Re: dirtybee] #159108
12/01/08 12:10 AM
12/01/08 12:10 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
Make sure the adjustment bolts on the lca are lined up. you have to be able to adjust. Sounds obvious but
I agree do the torsion bars last.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
