Ok, I have the K frame bolted to the car with all susp parts together except the uca are not connected to the spindles. I have the t bars through the crossmember. The lca are hanging all the way down. I put the t bars in the lca sockets and that went fine but now I can't lift the lca to meet up with the ball joint in the uca. Do I have to have the lca raised a little and if you do how do you make it even side to side. Thanks
