Re: 48° cam core question
[Re: clonestocker]
#1590429
03/09/14 03:41 PM
03/09/14 03:41 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I may still have a 48 degree for standard cam journals.
That are several 48 degree cores. standard journal, 2" babbit. 50mm roller, 60mm roller. Now I hear some have ran a 55mm roller.
If you waited months for one you did not call the right people.
Leon
[Re: Leon441]
#1590430
03/09/14 05:28 PM
03/09/14 05:28 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Leon
So there is a difference between a 48° cam and a 59° cam?
This is an R1 block BTW. A standard cam out of my 360 fits perfect.
[Re: SpareParts]
#1590431
03/09/14 07:22 PM
03/09/14 07:22 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
So you guys have BBC main journal cam cores? Great, how much are you asking? What lobe sizes? What lca? Thanks for letting us know!! ![](/ubbthreads/images/graemlins/laugh2.gif)
Brian Hafliger
[Re: Brian Hafliger]
#1590432
03/09/14 07:28 PM
03/09/14 07:28 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Is your block actually 48 degree ? I think most of the R-1's were 59 , but it's easy enough to tell.
The 48 degree lifter bores will be visibly further away from the valley wall than the 59 degree.....and with the different lifter center line , you need to compensate for this with lobe location. I don't think you can grind a 48 degree profile on a 59 degree blank , but I could be wrong. I seriously doubt an aggressive profile could be done.
[Re: tubtar]
#1590433
03/09/14 07:33 PM
03/09/14 07:33 PM
SpareParts
Janesville, WI
Yes, it is in fact 48°, it's got the goofy looking valley lol.
#1590436
03/09/14 08:11 PM
03/09/14 08:11 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
yeah I kinda thought we contacted quite a few folks on this matter...
[Re: SpareParts]
#1590441
03/09/14 09:22 PM
03/09/14 09:22 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
But I do have a 48* r1 block. So they are made.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1590442
03/09/14 09:24 PM
03/09/14 09:24 PM
SpareParts
Janesville, WI
I think I am alright, it fit a 59° cam just fine. I am new to the after market blocks and went off the part number (as did the seller) so no bad blood, I learned another lesson as I see it. And it was a deal, I've sold stock blocks for more. I'll try and get it checked out by someone who knows it before I buy more lessons lol
[Re: SpareParts]
#1590444
03/09/14 09:39 PM
03/09/14 09:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Then yes there is a special cam blank for a 48* babbit block... a 59* the lifters are farther apart on the cam itself and not ground on a 48* lifter angle so no a 59* will NOT work ![](/ubbthreads/images/graemlins/wave.gif)
