Re: 48° cam core question
[Re: clonestocker]
#1590429
03/09/14 03:41 PM
03/09/14 03:41 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I may still have a 48 degree for standard cam journals.
That are several 48 degree cores. standard journal, 2" babbit. 50mm roller, 60mm roller. Now I hear some have ran a 55mm roller.
If you waited months for one you did not call the right people.
Leon
[Re: Leon441]
#1590430
03/09/14 05:28 PM
03/09/14 05:28 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Leon
So there is a difference between a 48° cam and a 59° cam?
This is an R1 block BTW. A standard cam out of my 360 fits perfect.
[Re: SpareParts]
#1590431
03/09/14 07:22 PM
03/09/14 07:22 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
So you guys have BBC main journal cam cores? Great, how much are you asking? What lobe sizes? What lca? Thanks for letting us know!!
Brian Hafliger
[Re: Brian Hafliger]
#1590432
03/09/14 07:28 PM
03/09/14 07:28 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Is your block actually 48 degree ? I think most of the R-1's were 59 , but it's easy enough to tell.
The 48 degree lifter bores will be visibly further away from the valley wall than the 59 degree.....and with the different lifter center line , you need to compensate for this with lobe location. I don't think you can grind a 48 degree profile on a 59 degree blank , but I could be wrong. I seriously doubt an aggressive profile could be done.
[Re: tubtar]
#1590433
03/09/14 07:33 PM
03/09/14 07:33 PM
SpareParts
Janesville, WI
Yes, it is in fact 48°, it's got the goofy looking valley lol.
#1590436
03/09/14 08:11 PM
03/09/14 08:11 PM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
yeah I kinda thought we contacted quite a few folks on this matter...
[Re: SpareParts]
#1590441
03/09/14 09:22 PM
03/09/14 09:22 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
But I do have a 48* r1 block. So they are made.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1590442
03/09/14 09:24 PM
03/09/14 09:24 PM
SpareParts
Janesville, WI
I think I am alright, it fit a 59° cam just fine. I am new to the after market blocks and went off the part number (as did the seller) so no bad blood, I learned another lesson as I see it. And it was a deal, I've sold stock blocks for more. I'll try and get it checked out by someone who knows it before I buy more lessons lol
[Re: SpareParts]
#1590444
03/09/14 09:39 PM
03/09/14 09:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Then yes there is a special cam blank for a 48* babbit block... a 59* the lifters are farther apart on the cam itself and not ground on a 48* lifter angle so no a 59* will NOT work
