48° cam core question #1590426
03/09/14 02:31 PM
03/09/14 02:31 PM
Janesville, WI
SpareParts Offline OP
Janesville, WI
On a block with standard can journals is there a different can core because of the 48° lifters or is a standard can okay to use? Thanks, first of many questions to come
Re: 48° cam core question [Re: SpareParts] #1590427
03/09/14 03:28 PM
03/09/14 03:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
it took literally four months to find a usable core for my 9.2 deck 340 main, 48* siamese block with the babbit journals.
Re: 48° cam core question [Re: J_BODY] #1590428
03/09/14 03:33 PM
03/09/14 03:33 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Jay, You never checked with the right person
[img] [/img]
Re: 48° cam core question [Re: clonestocker] #1590429
03/09/14 03:41 PM
03/09/14 03:41 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I may still have a 48 degree for standard cam journals.
That are several 48 degree cores. standard journal, 2" babbit. 50mm roller, 60mm roller. Now I hear some have ran a 55mm roller.
If you waited months for one you did not call the right people.
Leon
Re: 48° cam core question [Re: Leon441] #1590430
03/09/14 05:28 PM
03/09/14 05:28 PM
Janesville, WI
Janesville, WI
Leon
So there is a difference between a 48° cam and a 59° cam?
This is an R1 block BTW. A standard cam out of my 360 fits perfect.
Re: 48° cam core question [Re: SpareParts] #1590431
03/09/14 07:22 PM
03/09/14 07:22 PM
SoCal
Brian Hafliger Offline
SoCal
So you guys have BBC main journal cam cores? Great, how much are you asking? What lobe sizes? What lca?
Thanks for letting us know!!
Brian Hafliger
Re: 48° cam core question [Re: Brian Hafliger] #1590432
03/09/14 07:28 PM
03/09/14 07:28 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Is your block actually 48 degree ? I think most of the R-1's were 59 , but it's easy enough to tell.
The 48 degree lifter bores will be visibly further away from the valley wall than the 59 degree.....and with the different lifter center line , you need to compensate for this with lobe location.
I don't think you can grind a 48 degree profile on a 59 degree blank , but I could be wrong. I seriously doubt an aggressive profile could be done.
Re: 48° cam core question [Re: tubtar] #1590433
03/09/14 07:33 PM
03/09/14 07:33 PM
Janesville, WI
Janesville, WI
Yes, it is in fact 48°, it's got the goofy looking valley lol.
Re: 48° cam core question [Re: SpareParts] #1590434
03/09/14 07:43 PM
03/09/14 07:43 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Don't let the filled in valley be your guide.......340 replacement had this too , but it doesn't mean you have a 48 degree block.
The lifter bore center lines are roughly 1/2 " further from the valley wall on a 48 degree.
59 degree bores are very close to the valley wall and if you see the two side by side , it is easy to tell them apart.
Re: 48° cam core question [Re: tubtar] #1590435
03/09/14 07:54 PM
03/09/14 07:54 PM
Janesville, WI
Janesville, WI
Good advice, I should have mentioned that the part number says it's 48.... that would have saved us some posts lol, scatter brained today
It's P4532435 if that helps
Re: 48° cam core question [Re: Brian Hafliger] #1590436
03/09/14 08:11 PM
03/09/14 08:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
yeah I kinda thought we contacted quite a few folks on this matter...
Re: 48° cam core question [Re: J_BODY] #1590437
03/09/14 08:51 PM
03/09/14 08:51 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
The king of small block Knowledge has spoken .........
But until about 2 Months ago you could not get 48* 1.998" plain bearing cams.
Danny may at midway performance (Predator cams) had 150 cores made
On side note the OP the 48* with stepped bearings in stock at 2 or 3 cam grinders much easier to get the core you need
Re: 48° cam core question [Re: SpareParts] #1590438
03/09/14 09:03 PM
03/09/14 09:03 PM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
To answer your question
NO you cant use a 59° cam in a 48° block even if the journals are the same.
Re: 48° cam core question [Re: CRIKEY] #1590439
03/09/14 09:13 PM
03/09/14 09:13 PM
Janesville, WI
Janesville, WI
Thanks guys.
Sad story I got to really looking it over at the shop after tubtar's posts, it looks like it's a 59° so must be a resto block?? Idk I searched the part number and found a ton of stuff saying it's 48° but sure doesn't look different. I'm into it cheap and it's better than what I had so it's not a total loss.
Re: 48° cam core question [Re: SpareParts] #1590440
03/09/14 09:19 PM
03/09/14 09:19 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Thanks guys.
Some of the blocks were messed up and had 48* cam core with 59* lifter valley! hope it's not one of those.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 48° cam core question [Re: SpareParts] #1590441
03/09/14 09:22 PM
03/09/14 09:22 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
But I do have a 48* r1 block. So they are made.
Re: 48° cam core question [Re: 1967dartgt] #1590442
03/09/14 09:24 PM
03/09/14 09:24 PM
Janesville, WI
Janesville, WI
I think I am alright, it fit a 59° cam just fine. I am new to the after market blocks and went off the part number (as did the seller) so no bad blood, I learned another lesson as I see it. And it was a deal, I've sold stock blocks for more.
I'll try and get it checked out by someone who knows it before I buy more lessons lol
Re: 48° cam core question [Re: SpareParts] #1590443
03/09/14 09:28 PM
03/09/14 09:28 PM
Janesville, WI
Janesville, WI
How would a fella tell if it was for a 48° cam core?
Bare with me guys I'm learning
Re: 48° cam core question [Re: SpareParts] #1590444
03/09/14 09:39 PM
03/09/14 09:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Then yes there is a special cam blank for a 48* babbit
block... a 59* the lifters are farther apart on the
cam itself and not ground on a 48* lifter angle so no
a 59* will NOT work
Re: 48° cam core question [Re: 1967dartgt] #1590445
03/09/14 10:07 PM
03/09/14 10:07 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Same here my r1a is so old that little plates were welded over the cam tunnel,thats how they use to beef it up.
I never ever saw a 59* block with the area above the cam solid like a 48* and i've had 3 restoration blocks which in my eyes is 100% an r series block.I wish i could post the picture instead of having to ask Brad or Brett..:)
