Re: Ed Hamburger Vintage Parts from the 1970's & 1980's
[Re: 1972CudaV21]
#1588741
03/06/14 06:32 PM
03/06/14 06:32 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I still have a set of Hamburger's "stocker" leaf springs,and a few other items.
[Re: Chris2581]
#1588742
03/06/14 07:35 PM
03/06/14 07:35 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Got a hamburger deep sump pan...needs a little repair ..have had it since 80s...
got a few small parts with his part numbers still on them...harden washers...5/64 4.07 ring set..probably reboxed sealed power rings..
and .984 tool steel 80 gram wrist pins..after buying them in the 80s finally put them in a engine last year...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: AndyF]
#1588743
03/06/14 07:45 PM
03/06/14 07:45 PM
BradH
One reason I started building my own parts was because the parts I bought from Hamburger were such poor quality.
Sounds like the same reason I switched to assembling my own engines after paying "professionals" to do the work and still experiencing issues that IMO could have been avoided.
[Re: DavidDean]
#1588745
03/07/14 03:03 PM
03/07/14 03:03 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
A bunch of us got the distributor stablizer (the collar with set screw to prevent the oil pump drive bouncing up and down changing timing conditions. Still have it, and lost count the number of motors it's been in.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1588746
03/07/14 03:24 PM
03/07/14 03:24 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
Do you think it helped?
[Re: AndyF]
#1588747
03/07/14 03:32 PM
03/07/14 03:32 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
One reason I started building my own parts was because the parts I bought from Hamburger were such poor quality. I looked at those parts and the price I paid for them and decided I could do better. That was a long time ago but it is one of the things that started me down the path of designing and building my own stuff.
We still have some of their overpriced stuff in the attic.Some of their oil pan designs are good for lawn sprinklers and some of their internal parts are great for comming apart and causing engine failres.
[Re: DusterW2]
#1588751
03/08/14 11:50 PM
03/08/14 11:50 PM
1972CudaV21
Connecticut
I bought the street/strip oil pan for a 340. The pan fit well and did not hang down very far past the K-member. I think it was a 6 qt and had accel/decel baffles. I have a pic somewhere. If you want, I can post later tonight. Also, bought tool steel lightweight wrist pins. Tried to order parts after they moved to Wirtz, VA, but did not have much luck. I think whoever he sold the business to kept the name, but the service and tech dept was lousy. Still have an old performance catalog from the '80s.
John
If you can post up a pic of the street/strip oil pan, that would be great!
[Re: 1972CudaV21]
#1588752
03/09/14 11:06 AM
03/09/14 11:06 AM
Posts: 1,537 hiding in illinois
slax69gts
hiding in illinois
a year ago at a swap meet in milwaukee i bought a welded sheet aluminium oil pan for my 470. the seller said it was a ed hamburger unit but there were no markings or tags. i did a web search but the closest pan i found was one that 440 source had that was kind of like it. seems he did alot of cheby stuff. i cleaned it up and had the external pick up hole welded up then knocked in two holes for a swinging pick up. i may use it, maybe not...
[Re: sixpacksteve]
#1588754
03/09/14 11:41 AM
03/09/14 11:41 AM
B G Racing
Eighty Four, PA
Not knocking anyones product but simply recalling old issues that we seen with some of their parts ie: Distributer shaft stabalizers that fell apart and cause major internal engine damage. Oil pans that leaked like lawn sprinklers at seams and welds. Crank scrapers and windage trays that cracked and caused internal damage as well as crank and rod interference.. Pan rails and bolt holes alignment and placement.
[Re: B G Racing]
#1588756
03/10/14 07:31 PM
03/10/14 07:31 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Had one of his aluminum 340 pans, with the tube for the center link. Had a pickup and plate that bolted directly onto the oil pump, after removing the rotor cover. First fire up on a new motor, the rotors bound up against the pickup plate,locking the oil pump and shearing the pin in the distributor drive. Needless to say that pan and pickup came right out.
[Re: B G Racing]
#1588757
03/11/14 01:25 AM
03/11/14 01:25 AM
1972CudaV21
Connecticut
Thanks for the reality check...lol. Did they make any good parts??
