8-3/4 rear end lube with suregrip? #1588028
03/04/14 05:32 PM
03/04/14 05:32 PM
Penna
70satelliteguy Offline OP
Penna
Do I need to use a special type with suregrip or just regular stuff?How much do I need to add? It is a new rebuilt 489 unit.
Re: 8-3/4 rear end lube with suregrip? [Re: 70satelliteguy] #1588029
03/04/14 05:36 PM
03/04/14 05:36 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yes you need friction modifier. 1 bottle of the FORD stuff (its very good) sold at Ford dealerships will do fine.
Re: 8-3/4 rear end lube with suregrip? [Re: Pacnorthcuda] #1588030
03/04/14 08:41 PM
03/04/14 08:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
does this help quiet down a high gear ratio?? i've heard it does...
Re: 8-3/4 rear end lube with suregrip? [Re: mikemee1331] #1588031
03/05/14 12:23 AM
03/05/14 12:23 AM
IN
ahy Offline
ahy  Offline
IN
Agree the lube of your choice plus sure grip additive. The parts store additive has worked fine in my clutch type. I believe it is GM spec. As far as the gear oil itself, generic parts store 80W90 will work fine for general use.
There may be benefits in something more expensive. Plan on sustained high speed running? A 140 rated oil (eg 90-140) may be better for the high temps. Synthetic 75 or 80W140 would be even better. Plan on arctic running? 75W90 synthetic would be better. Racers sometimes run significantly lighter oil to get the last .01 second. I never wanted to rebuild a rear end finding out "how light is too light" so I don't suggest going that route.
Re: 8-3/4 rear end lube with suregrip? [Re: ahy] #1588032
03/05/14 12:48 AM
03/05/14 12:48 AM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
I picked up a suregrip 8 3/4" last year & the guy gave me a bottle of if I remember right - fish oil - of some kind as a rearend additive. Anyone know what that;s about or is it just old school lube methods?
Re: 8-3/4 rear end lube with suregrip? [Re: edp] #1588033
03/05/14 12:50 AM
03/05/14 12:50 AM
That would be "whale oil". Years ago it was actually derived from whale blubber. Times have changed.
Re: 8-3/4 rear end lube with suregrip? [Re: Pacnorthcuda] #1588034
03/05/14 12:55 AM
03/05/14 12:55 AM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
hey maybe the "whale oil" bottle is now vintage & worth a boat load!
I thought it was a little funny but the bottle says something like "rearend additive"
Re: 8-3/4 rear end lube with suregrip? [Re: edp] #1588035
03/05/14 01:21 AM
03/05/14 01:21 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
"rearend additive"
somebody around here needed that a couple of weeks ago.
I am truckless..
Re: 8-3/4 rear end lube with suregrip? [Re: 340SHORTY] #1588036
03/05/14 01:27 AM
03/05/14 01:27 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
I have had good-luck with Mobil 1 ..... has a mild-scent of the old skunk-oil...
Re: 8-3/4 rear end lube with suregrip? [Re: 70satelliteguy] #1588037
03/05/14 01:46 AM
03/05/14 01:46 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Another vote for Ford Friction Modifier.
Re: 8-3/4 rear end lube with suregrip? [Re: 70Duster440] #1588038
03/05/14 01:56 AM
03/05/14 01:56 AM
I still have a plastic bottle of that MP "whale oil" sure grip additive
Re: 8-3/4 rear end lube with suregrip? [Re: RapidRobert] #1588039
03/05/14 03:01 AM
03/05/14 03:01 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I was wondering how long this stuff lasts.
I've got several years and about 12,000 miles on mine.
I'm going to replace the oil and ad new additive this spring but was curious if this stuff stops working after a while.
If I decide not to change my oil for a while would adding a bottle to the diff. be worth while?
Re: 8-3/4 rear end lube with suregrip? [Re: RapidRobert] #1588040
03/05/14 07:49 AM
03/05/14 07:49 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Actually called 'sperm oil'. Animal rights people get it pulled.
Re: 8-3/4 rear end lube with suregrip? [Re: MoparforLife] #1588041
03/05/14 11:45 AM
03/05/14 11:45 AM
Yeah iirc I had heard way back that it was NS1 but I just assumed Ma moved on to a better (or cheaper) product even tho I had heard it worked pretty good. Now we know
Re: 8-3/4 rear end lube with suregrip? [Re: mikemee1331] #1588042
03/05/14 01:20 PM
03/05/14 01:20 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
does nothing for the noise, just used so the clutches will slip on turns so the rear doesn't pop or chatter. In fact the correct way to use it is only use enough to quiet the rear and that's it, to much actually degrades the gear oil quality.
Re: 8-3/4 rear end lube with suregrip? [Re: ademon] #1588043
03/05/14 03:24 PM
03/05/14 03:24 PM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
does nothing for the noise ... only use enough to quiet the rear and that's it...
What?
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: 8-3/4 rear end lube with suregrip? [Re: BMChrysler68] #1588044
03/05/14 06:23 PM
03/05/14 06:23 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
What?
does nothing for a noisy gear, IE if the gear was set up wrong. only use enough to eliminate the clutch poping and chatter any more does not help the gear lube.
