Re: 8-3/4 rear end lube with suregrip?
[Re: Pacnorthcuda]
#1588030
03/04/14 08:41 PM
03/04/14 08:41 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Yes you need friction modifier. 1 bottle of the FORD stuff (its very good) sold at Ford dealerships will do fine.
does this help quiet down a high gear ratio?? i've heard it does...
[Re: edp]
#1588033
03/05/14 12:50 AM
03/05/14 12:50 AM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
I picked up a suregrip 8 3/4" last year & the guy gave me a bottle of if I remember right - fish oil - of some kind as a rearend additive. Anyone know what that;s about or is it just old school lube methods?
That would be "whale oil". Years ago it was actually derived from whale blubber. Times have changed.
[Re: edp]
#1588035
03/05/14 01:21 AM
03/05/14 01:21 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
"rearend additive" somebody around here needed that a couple of weeks ago.
I am truckless..
[Re: 70Duster440]
#1588038
03/05/14 01:56 AM
03/05/14 01:56 AM
RapidRobert
I still have a plastic bottle of that MP "whale oil" sure grip additive
[Re: RapidRobert]
#1588040
03/05/14 07:49 AM
03/05/14 07:49 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Actually called 'sperm oil'. Animal rights people get it pulled.
[Re: mikemee1331]
#1588042
03/05/14 01:20 PM
03/05/14 01:20 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
does nothing for the noise, just used so the clutches will slip on turns so the rear doesn't pop or chatter. In fact the correct way to use it is only use enough to quiet the rear and that's it, to much actually degrades the gear oil quality.
[Re: BMChrysler68]
#1588044
03/05/14 06:23 PM
03/05/14 06:23 PM
ademon
IL, Aurora
does nothing for the noise ... only use enough to quiet the rear and that's it...
What?
does nothing for a noisy gear, IE if the gear was set up wrong. only use enough to eliminate the clutch poping and chatter any more does not help the gear lube.
