hi guy's i am having problems with my 94 ram 1500 360 v8, bout 3 months back it started stalling intermittently half the time it would start back up,other times it just cranks over, and i could smell fuel. if it sits 15 or 20 mins it usually starts back up. in the last 5 or 6 months i have replaced the fuel pump<low pressure> coil and coil wire, full tune up, camshaft position sensor, auto shut down relay, crankshaft position sensor, battery, battery cables, common grounds, fuel pump relay. any help would be appreciated.
