94 ram1500 stalling #1587936
03/04/14 01:49 AM
03/04/14 01:49 AM
minnesota, USA
greenfire Offline OP
minnesota, USA
hi guy's i am having problems with my 94 ram 1500 360 v8, bout 3 months back it started stalling intermittently half the time it would start back up,other times it just cranks over, and i could smell fuel. if it sits 15 or 20 mins it usually starts back up. in the last 5 or 6 months i have replaced the fuel pump<low pressure> coil and coil wire, full tune up, camshaft position sensor, auto shut down relay, crankshaft position sensor, battery, battery cables, common grounds, fuel pump relay. any help would be appreciated.
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: 94 ram1500 stalling [Re: greenfire] #1587937
03/04/14 01:51 AM
03/04/14 01:51 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Codes? Fuel pressure when running?
Re: 94 ram1500 stalling [Re: greenfire] #1587938
03/04/14 01:58 AM
03/04/14 01:58 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I bet the EGR valve is dirty/sticking. Pop the EGR valve off and see if it carboned up or sticking open. They will cause the vehicle to stall. They can be cleaned with a little carb cleaner and a pocket screwdriver to scrape off the tough carbon. Use the carb cleaner to clean and wipe out the throttle body bores and IAC passage while you are at it.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 94 ram1500 stalling [Re: 71yelladustr] #1587939
03/04/14 10:06 PM
03/04/14 10:06 PM
minnesota, USA
minnesota, USA
well i swapped out the 6 month old coil with a new one, and so far no more stalling. i could have gotten a bad one right outta the box 6 months back. i will no more in a week or so, keeping my fingers crossed
