slant six -> small block
#1586692
03/01/14 09:03 PM
03/01/14 09:03 PM
Posts: 905 SD
zrxkawboy
SD
I have a '67 Belvedere 2-dr sedan with a 225/3-spd. I've been toying with the idea of swapping in a 360/727 out of my '74 Duster. I have a V8 K-member; which brackets/mounts do I need (are all SB brackets/mounts the same)? Also, what about the transmission mount? I guess those are my two main questions. Any other tips would be great. Thanks!
It's Swifty! Swifty, you toad sucker!
Re: slant six -> small block
[Re: Diplomat360]
#1586695
03/01/14 09:35 PM
03/01/14 09:35 PM
Posts: 4,848 Memphis
HemiRick
Memphis
No a 6 needs a v 8 k member to convert
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: zrxkawboy]
#1586704
03/02/14 01:29 PM
03/02/14 01:29 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
I did the /6 to 318 swap in my '70 Duster using the original /6 k member with a mid - '70's truck 318 bracket on the passenger side. The driver's side used a regular A body '67-72 318 bracket. This setup took mid - 70's 440 truck rubber isolators to get everything to line up correctly. They are thicker than the A body isolators and the offset for the mounting studs was correct. The A body isolators would not work due to the stud offset not lining up with the holes in the brackets and k member. Luckily I had a set of truck isolators in my pile of spare junk, and they worked perfect. Everything fit like a glove. Don't know if this would work on your B body? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Supercuda]
#1586705
03/02/14 05:02 PM
03/02/14 05:02 PM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
NOT AVAILABLE FOR AS ALREADY DISCUSSED AND POINTED OUT.
I suppose SHOUTING would really get your point across eh? Ohh...and the louder you get the more likely you are RIGHT...
Look, I'm sorry I'm not an expert on ALL Mopar body styles...the OP asked for a link, so there went my reply...in the meantime though, do you have anything positive to contribute to this discussion?
Unless I missed it, I haven't actually seen a reasonable contribution here from you in terms of an actual 'working' fix...feel free to SHOUT it out anytime now... ![](/ubbthreads/images/graemlins/pity.gif)
[Re: vdriver]
#1586706
03/02/14 07:55 PM
03/02/14 07:55 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i'm confused with the term 'bracket'?? is the the bracket that is on the motor mount or something totaly different?
[Re: mikemee1331]
#1586708
03/03/14 12:12 AM
03/03/14 12:12 AM
vdriver
Leucadia, Ca.
It's the motor mount bracket that bolts to the side of the engine. The rubber motor mount (isolator/biscuit) bolts to it and then to the k member. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: vdriver]
#1586709
03/03/14 02:19 AM
03/03/14 02:19 AM
Posts: 905 SD
zrxkawboy
SD
Thanks for the tip on the truck bracket, guys...I'll look into that. Otherwise, like I said, I do have a V8 K-member.
Anyone know about the trans mount?
[Re: zrxkawboy]
#1586710
03/03/14 08:52 AM
03/03/14 08:52 AM
Posts: 20,208 Park Forest, IL
slantzilla
Park Forest, IL
You should be able to use the one in the car.
