slant six -> small block #1586692
03/01/14 09:03 PM
03/01/14 09:03 PM
SD
Z
zrxkawboy Offline OP
Z
SD
I have a '67 Belvedere 2-dr sedan with a 225/3-spd. I've been toying with the idea of swapping in a 360/727 out of my '74 Duster. I have a V8 K-member; which brackets/mounts do I need (are all SB brackets/mounts the same)? Also, what about the transmission mount? I guess those are my two main questions. Any other tips would be great. Thanks!
It's Swifty! Swifty, you toad sucker!
Re: slant six -> small block [Re: zrxkawboy] #1586693
03/01/14 09:05 PM
03/01/14 09:05 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Instead of a K-frame replacement could you use the engine mounts swap instead?
Re: slant six -> small block [Re: Diplomat360] #1586694
03/01/14 09:08 PM
03/01/14 09:08 PM
SD
Z
Z
SD
I didn't realize they were available for my car. Could you provide a link?
Re: slant six -> small block [Re: Diplomat360] #1586695
03/01/14 09:35 PM
03/01/14 09:35 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
No a 6 needs a v 8 k member to convert
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: slant six -> small block [Re: HemiRick] #1586696
03/02/14 12:02 AM
03/02/14 12:02 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Doesn't Schumacher make conversion mounts?
Re: slant six -> small block [Re: slantzilla] #1586697
03/02/14 12:18 AM
03/02/14 12:18 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
You can also use a truck bracket on one side. With the /6 K frame.
Re: slant six -> small block [Re: slantzilla] #1586698
03/02/14 02:02 AM
03/02/14 02:02 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
nope, not that I saw and I looked.
Don't be the exception.
Re: slant six -> small block [Re: Supercuda] #1586699
03/02/14 02:42 AM
03/02/14 02:42 AM
Me too & I woulda sworn that they did
Re: slant six -> small block [Re: zrxkawboy] #1586700
03/02/14 12:01 PM
03/02/14 12:01 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Here it is => Schumacher Engine Mounts
Re: slant six -> small block [Re: Diplomat360] #1586701
03/02/14 12:14 PM
03/02/14 12:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
NOT AVAILABLE FOR AS ALREADY DISCUSSED AND POINTED OUT.
Re: slant six -> small block [Re: rt66jim] #1586702
03/02/14 12:21 PM
03/02/14 12:21 PM
I forgot all about that . Several guys have said that worked for them. Sure beats changing the K
Re: slant six -> small block [Re: RapidRobert] #1586703
03/02/14 12:31 PM
03/02/14 12:31 PM
SD
Z
Z
SD
Haven't heard of this. Details?
Re: slant six -> small block [Re: zrxkawboy] #1586704
03/02/14 01:29 PM
03/02/14 01:29 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I did the /6 to 318 swap in my '70 Duster using the original /6 k member with a mid - '70's truck 318 bracket on the passenger side.
The driver's side used a regular A body '67-72 318 bracket.
This setup took mid - 70's 440 truck rubber isolators to get everything to line up correctly. They are thicker than the A body isolators and the offset for the mounting studs was correct. The A body isolators would not work due to the stud offset not lining up with the holes in the brackets and k member. Luckily I had a set of truck isolators in my pile of spare junk, and they worked perfect.
Everything fit like a glove.
Don't know if this would work on your B body?
Re: slant six -> small block [Re: Supercuda] #1586705
03/02/14 05:02 PM
03/02/14 05:02 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I suppose SHOUTING would really get your point across eh? Ohh...and the louder you get the more likely you are RIGHT...
Look, I'm sorry I'm not an expert on ALL Mopar body styles...the OP asked for a link, so there went my reply...in the meantime though, do you have anything positive to contribute to this discussion?
Unless I missed it, I haven't actually seen a reasonable contribution here from you in terms of an actual 'working' fix...feel free to SHOUT it out anytime now...
Re: slant six -> small block [Re: vdriver] #1586706
03/02/14 07:55 PM
03/02/14 07:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'm confused with the term 'bracket'?? is the the bracket that is on the motor mount or something totaly different?
Re: slant six -> small block [Re: Diplomat360] #1586707
03/02/14 09:26 PM
03/02/14 09:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Comprehension isn't your forte is it?
Go back and read the postings, specifically mine and you will see that your link was useless as others, including myself, posted that there was not a swap kit for this setup and that we looked for the OP. More useful than your posts in this thread to date.
Re: slant six -> small block [Re: mikemee1331] #1586708
03/03/14 12:12 AM
03/03/14 12:12 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
It's the motor mount bracket that bolts to the side of the engine. The rubber motor mount (isolator/biscuit) bolts to it and then to the k member.
Re: slant six -> small block [Re: vdriver] #1586709
03/03/14 02:19 AM
03/03/14 02:19 AM
SD
Z
Z
SD
Thanks for the tip on the truck bracket, guys...I'll look into that. Otherwise, like I said, I do have a V8 K-member.
Anyone know about the trans mount?
Re: slant six -> small block [Re: zrxkawboy] #1586710
03/03/14 08:52 AM
03/03/14 08:52 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
You should be able to use the one in the car.
Re: slant six -> small block [Re: zrxkawboy] #1586711
03/03/14 03:15 PM
03/03/14 03:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've got a 1966 Dodge Coronet Deluxe six cylinder car, I found a V8 K member for the car from the saem year, I am looking for a 1968 or newer V8 K member so I can use the better 1968 and later idler arm instead of the early single bolt, stud one with no capture on the top to prevent the idler arm from flexing OP, changing the K member is not that hard, really
