Re: Hydraulic Roller in RB
[Re: ChevyTS]
#1585171
02/27/14 11:06 PM
02/27/14 11:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont know any mods that would have to be done... it has the oil galley for the lifters... most you would LIKE to do is bushings in the lifter bores but not a mandatory thing... I'm sure one of the guys that has done it will chime in
[Re: ChevyTS]
#1585172
02/27/14 11:22 PM
02/27/14 11:22 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Someone who's done it will have the answers.... I'm immagining that the height of the lifter body may not jive with the oil galley, which would be required for pressurizing the lifter.
Why go to a hydraulic roller? Cost vs. advantage is not worth it to me. A flat tappet solid will out-perform a hydraulic roller, and be much more reliable... Just sayin'.
[Re: AndyF]
#1585174
02/28/14 12:55 AM
02/28/14 12:55 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
No idea what Landy is talking about, a hyd roller setup works just fine in a big block Mopar. Perhaps it was a special racing situation or something where bolt on parts weren't going to work.
I had a Crane Hyd roller in my 440 & it worked fine. My bro had the same cam in his 440 & had issues with a valve tip breaking after about a year. ALmost dropped a valve & it might be that the builder didn't install a cam button.
[Re: Triggerfish]
#1585175
02/28/14 01:39 AM
02/28/14 01:39 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Don't know if it's true with a hyd roller but with a solid roller my experience was that you had to run a solid body lifter or you would lose oil pressure when the "cut-out" on the lifter came up out of the lifter bore...didn't realize what i had done and ran it that way for a season with low idle oil pressure, put solid body comps in the next season and oil pressure went back to normal, only then did I figure out what I had done.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: RapidusMaximus]
#1585176
02/28/14 05:37 AM
02/28/14 05:37 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
The lift is usually limited because of the oil galley thing, typically at around 0.54" with 1.5 rockers.
Plynouth VIP '67 TT IC EFI
[Re: ChevyTS]
#1585177
02/28/14 11:45 AM
02/28/14 11:45 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I recently read an article online about a 440 build that was going to use a retro roller conversion. Landy told the builders that a 440 block requires to many oiling system mods to use hydraulic roller lifters. Any ideas what mods he might be referring to? http://www.popularhotrodding.com/enginemasters/articles/mopar/bigblock/0107phr_bbmopar/
Not really sure either, what Landy would be concerned with in this type of application. ...I've got quite a few of them out there running just fine.
RIP Monte Smith
[Re: dogdays]
#1585182
02/28/14 03:55 PM
02/28/14 03:55 PM
Posts: 1,238 Nevada
dezduster
Nevada
Unfortunately, Landy's advice in the later years was often for the birds. His column in one of the Mopar magazines was usually good for a laugh.
R.
WOW! I would hope you are judging as you would want to be judged.
I typically am harsh while one is alive and able to defend ones self. After someone passes I always see them for who they actually were. If I can find nothing good to say about them I'll say nothing. Dick Landy is not a foot note to the MOPAR history but an entire chapter, He is also one who is noted throughout the MOPAR book and in other legends chapters as well. Don't go chopping at his achievements so you will feel taller next to them, GET TO ACHIEVING!!
[Re: ChevyTS]
#1585183
02/28/14 04:20 PM
02/28/14 04:20 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Landy's advice might have been about using factory SB lifters in a BB, the oil groove being exposed at max lift is a known issue with some lifters.
