Rear coilover shock spring rate? #1584574
02/26/14 04:33 PM
02/26/14 04:33 PM
WI.
Scotts71chall Offline OP
WI.
What rear coilover spring rate do I need?
1971 Challenger
4-link rear sus. Qa1 Proma Star shocks
Alum. head hemi, world block, 727 trans
Dana 60
Fiberglass Hood, Bumpers, Dash
Full Interior
Stock gas tank
Street/strip
Re: Rear coilover shock spring rate? [Re: Scotts71chall] #1584575
02/26/14 04:43 PM
02/26/14 04:43 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Do you have any idea what the rear axle weight is? I would guess that a 125 spring would put you pretty close but with out knowing for sure on the weight its just a guess.
Back in the swing of things at Painless again! Great to be back!
Re: Rear coilover shock spring rate? [Re: BJS racing] #1584576
02/27/14 12:19 PM
02/27/14 12:19 PM
WI.
WI.
I really wish I had more info, the car is very apart now. Im guessing 3700 - 3800 pounds when done.
I would think there would be many guys running B & E body cars with big blocks and 4-links or ladder bars with coilover shock setups?
Maybe they just don't remember what spring they have on. I wanted to get them with the summit discount.
Re: Rear coilover shock spring rate? [Re: Scotts71chall] #1584577
02/27/14 01:04 PM
02/27/14 01:04 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Being a little soft on the springs is much easier to work with than being left with too stiff of a spring. I would get a set of 125's and go from there. you can always run the spanner up on the spring and store some energy in the spring and the car will actually work better. If you go to stiff you really won't get as much out of the shocks as you should. just my
Re: Rear coilover shock spring rate? [Re: Scotts71chall] #1584578
02/27/14 01:18 PM
02/27/14 01:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 3700-3800 isnt gonna help much.. you need to know
the rear weight... then subtract the unsprung weight
then see what they want for the manufacturers design
height for the shock... for the general spec its
5/8 of the stroke inside the shock.. set the bottom
spanner up 1" and if the spring is right it will
drop down in to that 5/8 point.. if its within 1"
you can adjust that.. if its greater then you need
to change the springs.... as a GUESS the 125#-130#
should be real close.... if the body isnt setting
at the height correctly then you move the bottom of
the shock to get it right... dont just crank up the
spanner(you would be going out of the design height)
Re: Rear coilover shock spring rate? [Re: MR_P_BODY] #1584579
02/27/14 01:32 PM
02/27/14 01:32 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Yeah I was just talking about to get the ride height eye to eye set properly. Guess I should have said that. Was just trying to get my uneducated opinion on suggested spring rate to him. Set up after parts!
Re: Rear coilover shock spring rate? [Re: BJS racing] #1584580
02/27/14 01:41 PM
02/27/14 01:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same as my uneducated opinion... without any real
info all this is just a guess... but it should get
him in the ball park
Re: Rear coilover shock spring rate? [Re: MR_P_BODY] #1584581
02/27/14 03:29 PM
02/27/14 03:29 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
I have 130# on mine, that is probably close.
Good Luck
Re: Rear coilover shock spring rate? [Re: BJS racing] #1584582
02/27/14 04:22 PM
02/27/14 04:22 PM
My NHRA legal A/S 1970 Baracuda 426 Street Hemi weighed 2160 lbs on the front tires and around 1280 lbs on the rear with no driver and a 1/2 tank of gas. That car was a original 383 4 speed car that had a K member and engine out of a 1968 Hemi Road runner, E body Dana 60 rear, Shaker hood and no roll bar, stock front and back seats, no console,no heater or radio Them babys are way nose heavy I help another couple that raced a 1970 Challenger R/T that we put a street hemi motor in it also to run NHRA legal A/SA, it had similar weights on the front and back tires IHTHs
Re: Rear coilover shock spring rate? [Re: Cab_Burge] #1584583
02/27/14 09:30 PM
02/27/14 09:30 PM
Penna
70satelliteguy Offline
Penna
I run 130 lb. springs with ladder bars at 3600 race weight B body. Mid 9 sec BB. 1.30 60 ft. I changed from 160's and they did not work nearly at good as the lighter springs.
Re: Rear coilover shock spring rate? [Re: 70satelliteguy] #1584584
02/27/14 11:53 PM
02/27/14 11:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I think your weight estimate is high. My bet is 3400+/-. I use 125# on my ladder bar 64 Belvedere. Car weighs 3340 ready to race. The rear weighs 1536. The unsprung weight is 330#. Shocks are mounted behind the rear axle. 125/130 will be very close. If you have a lot of power or run on drag radials you may want to go to 150 for less stored energy as you may not need as much "hit". For the record mine makes around 875hp.
Doug
Re: Rear coilover shock spring rate? [Re: Scotts71chall] #1584585
02/28/14 01:46 AM
02/28/14 01:46 AM
WI.
WI.
Many thanks to all! 130s are on order
Re: Rear coilover shock spring rate? [Re: Scotts71chall] #1584586
02/28/14 02:48 AM
02/28/14 02:48 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Interesting thread for me.... i had traction issues (soomtimes) last summer with my new ladder set up. Guess what springs? 150 lb.
i have a new 125 lb set sitting here to try this April
Re: Rear coilover shock spring rate? [Re: 493_DART] #1584587
02/28/14 03:08 AM
02/28/14 03:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have 150s on it now and you measure the design
length(eye to eye) I'm sure that its longer than
it should be... in that case you could be topping
them out which causes the loss of traction... on
some days the track might be better and those are
the days you probably lost traction
Re: Rear coilover shock spring rate? [Re: MR_P_BODY] #1584588
02/28/14 03:13 AM
02/28/14 03:13 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
it would get worse as they day went on and also if it got hot out.
Usually it would dead hook hard the first 1 to 3 passes...then start spinning slightly the rest of the race day
Re: Rear coilover shock spring rate? [Re: 493_DART] #1584589
02/28/14 03:20 AM
02/28/14 03:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The first few runs it was planting the tire hard enough
to set the tires and the shocks worked good at that
point... did you ever loosen up your shocks when
it would spin... maybe just 1 or 2 settings
Re: Rear coilover shock spring rate? [Re: MR_P_BODY] #1584590
02/28/14 11:41 AM
02/28/14 11:41 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
What we learned over the years is that you want just enough spring to hold the back of the car up, then adjust the shock setting for traction and control, it works great at the track as too heavy of a spring negates the shock adjustments.
Then, if you REALLY drive it on the street, like Drag Week for example, and you have a buddy with you, and possibly some luggage, or spare parts, it's going to beat you, the shocks, and the suspension to death in about 300 miles because the springs simply can't control the weight under adverse driving conditions! I learned this lesson at DW 2011, and my brother suffered the same problem at DW2013. So if you truly intend to use it on the street, you might want a set of 150 or 160s to slap on in that situation.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Rear coilover shock spring rate? [Re: MR_P_BODY] #1584591
03/01/14 04:33 AM
03/01/14 04:33 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
oh believe me... i tried everything... cant wait to try my new 125 lb springs.
Re: Rear coilover shock spring rate? [Re: 493_DART] #1584592
03/01/14 05:00 AM
03/01/14 05:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe that will help also
