Re: Rear coilover shock spring rate?
[Re: Scotts71chall]
#1584575
02/26/14 04:43 PM
02/26/14 04:43 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
Do you have any idea what the rear axle weight is? I would guess that a 125 spring would put you pretty close but with out knowing for sure on the weight its just a guess.
Back in the swing of things at Painless again! Great to be back!
[Re: Scotts71chall]
#1584578
02/27/14 01:18 PM
02/27/14 01:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I really wish I had more info, the car is very apart now. Im guessing 3700 - 3800 pounds when done. I would think there would be many guys running B & E body cars with big blocks and 4-links or ladder bars with coilover shock setups? Maybe they just don't remember what spring they have on. I wanted to get them with the summit discount.
The 3700-3800 isnt gonna help much.. you need to know the rear weight... then subtract the unsprung weight then see what they want for the manufacturers design height for the shock... for the general spec its 5/8 of the stroke inside the shock.. set the bottom spanner up 1" and if the spring is right it will drop down in to that 5/8 point.. if its within 1" you can adjust that.. if its greater then you need to change the springs.... as a GUESS the 125#-130# should be real close.... if the body isnt setting at the height correctly then you move the bottom of the shock to get it right... dont just crank up the spanner(you would be going out of the design height)
[Re: BJS racing]
#1584582
02/27/14 04:22 PM
02/27/14 04:22 PM
Posts: 43,236 Bend,OR USA
Cab_Burge
My NHRA legal A/S 1970 Baracuda 426 Street Hemi weighed 2160 lbs on the front tires and around 1280 lbs on the rear with no driver and a 1/2 tank of gas. That car was a original 383 4 speed car that had a K member and engine out of a 1968 Hemi Road runner, E body Dana 60 rear, Shaker hood and no roll bar, stock front and back seats, no console,no heater or radio Them babys are way nose heavy I help another couple that raced a 1970 Challenger R/T that we put a street hemi motor in it also to run NHRA legal A/SA, it had similar weights on the front and back tires IHTHs
[Re: 493_DART]
#1584587
02/28/14 03:08 AM
02/28/14 03:08 AM
MR_P_BODY
Interesting thread for me.... i had traction issues (soomtimes) last summer with my new ladder set up. Guess what springs? 150 lb.
i have a new 125 lb set sitting here to try this April
If you have 150s on it now and you measure the design length(eye to eye) I'm sure that its longer than it should be... in that case you could be topping them out which causes the loss of traction... on some days the track might be better and those are the days you probably lost traction
[Re: 493_DART]
#1584589
02/28/14 03:20 AM
02/28/14 03:20 AM
MR_P_BODY
it would get worse as they day went on and also if it got hot out.
Usually it would dead hook hard the first 1 to 3 passes...then start spinning slightly the rest of the race day
The first few runs it was planting the tire hard enough to set the tires and the shocks worked good at that point... did you ever loosen up your shocks when it would spin... maybe just 1 or 2 settings
[Re: MR_P_BODY]
#1584590
02/28/14 11:41 AM
02/28/14 11:41 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
What we learned over the years is that you want just enough spring to hold the back of the car up, then adjust the shock setting for traction and control, it works great at the track as too heavy of a spring negates the shock adjustments. Then, if you REALLY drive it on the street, like Drag Week for example, and you have a buddy with you, and possibly some luggage, or spare parts, it's going to beat you, the shocks, and the suspension to death in about 300 miles because the springs simply can't control the weight under adverse driving conditions! I learned this lesson at DW 2011, and my brother suffered the same problem at DW2013. So if you truly intend to use it on the street, you might want a set of 150 or 160s to slap on in that situation.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MR_P_BODY]
#1584591
03/01/14 04:33 AM
03/01/14 04:33 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
oh believe me... i tried everything... cant wait to try my new 125 lb springs.
