Glyptal/internal engine painting questions #1584048
02/25/14 03:51 AM
02/25/14 03:51 AM
White Creek, NY
408cuda Offline OP
408cuda  Offline OP
White Creek, NY
I have an unopened can several years old that I could just never pull the trigger and use on anything I built for myself or others. It's a nice idea but seems like an area for another potential disaster. Lots of people paint every inch inside with this or maybe something similar but I gotta wonder what happens if things aren't spotless, or even on small spot starts to lift? Seems like it would eventually all peel off, especially if you had hard edges which is inevitable. How are you guys doing it, right after hot tank? I can't imaging getting it clean enough with just thinner but maybe I'm wrong? I smoothed the lifter valley with carbides and paper in my own 408 to get some of the benefit without having to break my can open and actually try the stuff.
Thoughts for or against?
Re: Glyptal/internal engine painting questions [Re: 408cuda] #1584049
02/25/14 04:25 AM
02/25/14 04:25 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Never had a problem with it. I just cleaned the blocks beforehand with degreaser, then soap and HOT water.
Re: Glyptal/internal engine painting questions [Re: topside] #1584050
02/25/14 05:08 AM
02/25/14 05:08 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I think it's a waste of time and a perfectly good paint brush. It does look cool in the magazines.
Re: Glyptal/internal engine painting questions [Re: Jeremiah] #1584051
02/25/14 07:57 AM
02/25/14 07:57 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have seen a few instances where it has lifted off, but I have seen many, many engines that have been internally painted and never had an issue. The last one I did still looked it had just been painted when it was freshened.
Alan Jones
Re: Glyptal/internal engine painting questions [Re: 408cuda] #1584052
02/25/14 09:16 AM
02/25/14 09:16 AM
Truckville, the capital of NY
85_Ram_4speed Offline
I actually have used the red oxide Rustoleum rusty metal primer from a rattle can on cleaned blocks and have had excellent results over the years. All the blocks I have done come from the machinest bake and blast machine and then I wash them with hot soapy water and dried for at least a couple hours.
I just do it to help keep any flash over or surface rust from forming during the build and help seal the pores in the metal. Sometimes I do the whole block, other times it's just the lifter valley timing chain area. It's just a pain to mask when you spray, but I like the results.
383 build:
440 build:
Brand X build:
Outcast Dodge guy.
Re: Glyptal/internal engine painting questions [Re: 408cuda] #1584053
02/25/14 11:19 AM
02/25/14 11:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Every R3 block I have seen is painted in the valley..
I do it on all of my junk and so far its never lifted
Re: Glyptal/internal engine painting questions [Re: Jeremiah] #1584054
02/25/14 02:49 PM
02/25/14 02:49 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I would disagree on this. It does much more than just look cool...lol.
RIP Monte Smith
Re: Glyptal/internal engine painting questions [Re: Jeremiah] #1584055
02/25/14 05:52 PM
02/25/14 05:52 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
What functional purpose does it serve. I use oven cleaner to remove it when I get an engine that someone has applied it to.
Re: Glyptal/internal engine painting questions [Re: qwkmopardan] #1584056
02/25/14 06:07 PM
02/25/14 06:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you know why its put in there? to allow the oil
to return easier... every bit of rough casting slows
the oil from returning... if you want you can polish
it but the paint is easier and does work
Re: Glyptal/internal engine painting questions [Re: MR_P_BODY] #1584057
02/25/14 10:14 PM
02/25/14 10:14 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Funny, on modern race engines oil is trapped in the top of engine and routed to the pan at the very rear or very front to keep the oil from attempting to pass through the rotating crankshaft assembly where most of it will churn in the crank and will cause drag and loss of power. And very little will make it to the pan anyway under hard accelleration. Ever look at a GM rocket block or a ritter small block mopar? Ideally, a dry sump would be best, with 3 scavenge lines in the pan and one in the valley. You don't see glyptol in a pro/stock or fuel engine. Waste your time if you want, I will trap the oil and let it return to the pan on coast or deceleration.
P-body, I would love to buy your car and put a flat tappet cam, strip the glyptol paint, freshin it up, put a Dana 60 in it and go run some 8.50s on gas.
Re: Glyptal/internal engine painting questions [Re: qwkmopardan] #1584058
02/25/14 10:49 PM
02/25/14 10:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Show me a fuel motor that isn't a beautifully machined billet! They have no pores and are pretty darn smooth.
Re: Glyptal/internal engine painting questions [Re: qwkmopardan] #1584059
02/25/14 10:52 PM
02/25/14 10:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll keep the paint in it...it does have a dry sump..
I will refresh it for who ever buys it.. and yes it
would
run 8.50 if I regrind the cam... but I wimped out
on the cam the first time
Re: Glyptal/internal engine painting questions [Re: CompWedgeEngines] #1584060
02/26/14 12:22 AM
02/26/14 12:22 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
And I'd like to add
Mine has been on there 15 years. After the block was clean. I washed it with laquer thinner, then hit it with Brake Kleen just before I brushed 3 coats on, top to bottom.
I find it easier to notice any little bit of debris. Fine metal particles, valve train parts, etc.
If there is dirt anywhere it can be wiped out with a paper shop towel, in one piece
Hope I never have to find out but I think you might be able to find a crack, should one appear
And...... It Aids Oil Drain Back! New motor technology starts with race motor technology. My 1969 block from an Imperial was never meant to push 650HP @ 7,200 RPM with a tall rotor Milodon pump. I'll take my oil to the pan as soon as I can get it there while keeping it off the rotating assembly.
I know I'm missing something, it's been so long since I've touched the Barracuda
Re: Glyptal/internal engine painting questions [Re: roadhazard] #1584061
02/26/14 03:17 AM
02/26/14 03:17 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would like to see if anyone can actually come up with a measurable gain for a painted vs. unpainted block. With the way hot oil flows down hill don't see the performance benefit being anything beyond negligible. The line items Greg listed are definitely good aspects that would promote painting the block.
So now that you guys are starting to win me over where does one get this super oil flowing paint?
Re: Glyptal/internal engine painting questions [Re: Jeremiah] #1584062
02/26/14 04:09 AM
02/26/14 04:09 AM
White Creek, NY
408cuda Offline OP
408cuda  Offline OP
White Creek, NY
Thanks for all the replies guys. I don't see/hear much about it peeling off just a personal fear. Suppose I got to break down and try it at some point and see for myself. I like the oil drain prospects but also sealing the casting pores. Like concrete cast iron seems to dust eternally.
Eastwood is where I bought the can I have. Used a gift certificate I got to there on it. Wonder if its still good? Been years on the shelf but don't think its frozen ever. Anyway thanks again.
Re: Glyptal/internal engine painting questions [Re: 408cuda] #1584063
02/26/14 12:16 PM
02/26/14 12:16 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
With even a reasonable cleaning the glyptol should adhere well enough that it shouldn't be a concern. The stuff is tough, originally made to be used on electric motors which can get pretty hot! I've seen blocks come out of the hot tank and the glyptol remained completely untouched.
I've always used the spray can stuff - I hate brush-painting anything! I used corks to plug the lifter bores and I only bothered doing the valley, not the rest of the block.
I doubt you'd see even a minute HP gain from this since all it supposedly does it provide a smooth surface for the oil to flow down. You'd have to do some other mods to keep it away from the rotating assembly before you'd see HP gains.
I stopped using the stuff over 20 years ago. With the tools available now I can quickly get into every part of a block and knock out every bit of flash or casting crud and I'm happy with that.
Re: Glyptal/internal engine painting questions [Re: Stanton] #1584064
02/26/14 01:20 PM
02/26/14 01:20 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's not to be used on alcohol. The paint can says so.
Re: Glyptal/internal engine painting questions [Re: CompWedgeEngines] #1584065
02/26/14 01:51 PM
02/26/14 01:51 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Can you enlighten us with a list of the "much more"?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Glyptal/internal engine painting questions [Re: DusterDave] #1584066
02/26/14 09:32 PM
02/26/14 09:32 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I worked for a utility company in Pittsburgh and we used it on high voltage Transformer tanks and winding leads. We had a huge problem with insulating oils becoming acidic due to degradation over time and condensation. Glyptal was the only thing that solved our problems. I have never seen it fail or degrade even in the very worst super high voltage, high temperature situations. Our Network operators and mechanics developed all kinds of uses for it including spot rust proofing on Downtown Network Transformers which are almost always partially submerged in water that had salt in it from winter sidewalk maintenance. A couple of coats of it on Breaker or Transformer leads often served as a very good insulator when normal insulating materials could not be used. I have also seen it used as a gasket sealer on high pressure Transformer oil Tanks. I can honestly say that this stuff was on every one of our trucks and is the first thing restocked if there was any danger of running out. Just from someone that used it daily for over 40yrs.
Re: Glyptal/internal engine painting questions [Re: b1dartsport] #1584067
02/26/14 09:43 PM
02/26/14 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All I can say about this subject is it does allow the
oil to return quicker to the bottom... if your engine
is set up to allow the oil to return via the intake
valley then its no difference but it allows it quicker
to get there... I would prefer that than having the
oil up top in the valley doing nothing but draining
the pan... get it back as best you can... if you dont
like it hitting the crank then direct it to the rear
and drop it down there.. oil laying in the top is a
waste of oil........ JMO
