Page 2 of 3 1 2 3
Re: Aluminum heads and spark plugs [Re: fullmetaljacket] #1583815
02/25/14 09:03 PM
02/25/14 09:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Chassis being a factory production chassis and frame being a tube frame as in fabricated car?
From what you are saying I call it backwards then...
when I say a chassis car.. thats meaning a tube chassis
car.. frame as in a production car... I do ground the
heads to the chassis but I use the chassis as the
ground link... so far I've never had a problem.. I
always looked at it like.. if you roll that .083 tubing
into a solid roll its greater than the 1/2" ground
cable... and thats just one side of the chassis...
electricity will always travel the easiest way(least
resistance)
Re: Aluminum heads and spark plugs [Re: MR_P_BODY] #1583816
02/25/14 09:06 PM
02/25/14 09:06 PM
fullmetaljacket Offline
That's what I thought.
Re: Aluminum heads and spark plugs [Re: fullmetaljacket] #1583817
02/25/14 10:46 PM
02/25/14 10:46 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
This is an odd topic for me...or I just got lucky , I ve run aluminum heads for years, never used anti-seize or grounded anything special never had any issues.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Aluminum heads and spark plugs [Re: RapidusMaximus] #1583818
02/25/14 10:57 PM
02/25/14 10:57 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I was told by a tech guy at ngk that it screws with the plugs ability to transfer heat. This in turns changes the heat range on the plug.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583819
02/26/14 12:31 AM
02/26/14 12:31 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I do agree the chassis should be a good ground being you run your Neg off the battery to the chassis.I was having problems a few years back when I put my 1st all aluminum engine in my dragster and thought the chassis was good enough I even had my MSD ground bolted to it instead of the battery.But when I grounded each head to the same spot on the block as well as my MSD ground and run a ground cable to the Neg (which is ground to the chassis)like the MSD tech. said all my problems went away. I can grin about it now but when I was having problems,I did not think it was very funny and the tech. at MSD had a hard time making me believe it had to be that way.
PS I like to think that sometimes us Racers are just to smart for our own good....but I guess the Truth be told we are just to Hard-Headed to listen.
Sometimes I don't know why my car even runs
My hole car needs rewired and I'm not looking forward to it.
That's interesting 1967artGT
Re: Aluminum heads and spark plugs [Re: roadhazard] #1583820
02/26/14 12:50 AM
02/26/14 12:50 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
They also advised us to ground each head separately to insure proper grounding with aluminum heads.
yea because the single bolt and wire you're going to use to ground the head is going to have less resistance than the 17 head fasteners and four fire rings
idk where thy come up with this stuff, if the block and ignition are properly grounded i just don't see where this is necessary
Re: Aluminum heads and spark plugs [Re: jamesc] #1583821
02/26/14 01:39 AM
02/26/14 01:39 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Interesting discussion...especially in regards to grounding the heads individually. Never heard any of this before
Re: Aluminum heads and spark plugs [Re: mshred] #1583822
02/26/14 02:53 AM
02/26/14 02:53 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve checked the non-grounded head and it completes current and is fine reading voltage.............interesting. I also probably use too much ante-seize so time to clean out the plug holes I guess.
Re: Aluminum heads and spark plugs [Re: Thumperdart] #1583823
02/26/14 10:42 AM
02/26/14 10:42 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I would say NO dont use it! Reason is it will NOT be grounded as well as it could be. How many of you have ever checked the fluid in the radiator to see how many volts are there? The fact of the matter is that most cars seem fine but the electronics Dont work as they should. Heck yes you should ground your heads and 4130 chassis is the worst but mild steel chassis car still needs alot more than you want to believe to be properly grounded.If your having problems misses,running the same time-get a volt meter out and check the DC/AC in each circuit on your ride. This is what I have learned
Re: Aluminum heads and spark plugs [Re: poisondart2] #1583824
02/26/14 12:59 PM
02/26/14 12:59 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I have actually been battling this problem for over a month now. Car ran fine below about 4K. Get above that and start running some boost and it starts missing. Seemed like an ignition problem, but after going through the entire ignition system ( multiple times ) I moved on to the fuel system and engine mechanicals. Verified the alternator was good. Volt gauge always ran around 14 volts. Ran a separate volt gauge directly off the distributor feed wire to make sure I was getting 14 vlts to it. When I would pull the plugs, they would always look good. Didn't even look at how much anti-seize was on the plug threads / washers. I was running out of ideas. Decided to put in a fresh set of plugs. Noticed there was a lot of anti-seize in the plug gasket area in the heads, so I wiped that area down and just used a drop of oil on the new plug threads. Engine missing problem gone! Blasts right up to 6500 and 15 lbs of boost without a glitch. I now have a spare ignition module, cap, rotor, alternator, valve springs, and a very clean fuel system.
Fastest 300
Re: Aluminum heads and spark plugs [Re: poisondart2] #1583825
02/26/14 01:46 PM
02/26/14 01:46 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Been there done that myself,I was just to stubborn to listen to the Tech.Reps @ MSD.
PS some times we overlook the simplest things or refuse to listen to what someone tells us because we just know that can't be the problem or we think there is no need to do it the way they say even if they make/build the product.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583826
02/26/14 04:03 PM
02/26/14 04:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
As far as not using antisieze on spark plugs in alumumin heads wait until you pull the threads out of one due to galling I had that happen on my airplane motor, not good I have been told the most of the new plugs for car applications now come with a anitiseize coating on them I do use it(Graphite type ) on all new plugs and anytime I remove one to look at it and resuse it do not let the graphite get onto the center of the plug, it is a great conductor of electricty, don't ask me how I know that
Re: Aluminum heads and spark plugs [Re: Cab_Burge] #1583827
02/26/14 04:13 PM
02/26/14 04:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
This will answer the question about antiseize.
http://www.ngksparkplugs.com/pdf/tb-0630111antisieze.pdf
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583828
02/26/14 05:18 PM
02/26/14 05:18 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Is the difference in quality of the grounding measurable? In other words would the the block to frame ground show a different ohm reading than the head to frame? Or different voltage reading from positive to head versus positive to block? Just aksing?
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Aluminum heads and spark plugs [Re: GomangoCuda] #1583829
02/26/14 05:22 PM
02/26/14 05:22 PM
GomangoCuda Offline
GomangoCuda  Offline
Grounding - From MSD Forum
We have discovered for decades now that the motor-plates and the ground strap to the block does not provide a sufficient ground. It was initially un-covered that the black etch marks that appear around the block holes of front and rear motor plates was made due to the poor ground paths(we even saw etches in main and rod bearings). With coated studs, aluminum heads, coated gaskets,powder coated frames and customers relaying on the ground strap from the chassis to the block was not enough.
To be frank, the spark plugs are in the head and not the block! With this in mind, it was best to have a common ground between the electronics, battery and even the coil to eliminate any floating ground issues that may occur. Majority of the time ,this elinminate "misses" ,tach issues,data logger problems..etc.
Look at the drawing below:
If diagram does not appear below then See attachment
Re: Aluminum heads and spark plugs [Re: GomangoCuda] #1583830
02/26/14 05:52 PM
02/26/14 05:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you are that stupid to break a plug installing them then you should not have tools.Period.Reminds me of the guy we had at work.He broke so many bolts it wasnt funny.He would get them as tight as he could then try to get another turn from them.Ive used antisieze since the late 70s.My buddy that does fab and works on big equipment and farm stuff dosent put much together without it.Only guy I know that buys it in gallon cans.Rocky
Chrysler Firepower
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583831
02/26/14 05:53 PM
02/26/14 05:53 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Thats a Moparts best quote right there
Re: Aluminum heads and spark plugs [Re: GomangoCuda] #1583832
02/26/14 05:56 PM
02/26/14 05:56 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Good piece of info there, I don't use autolite plugs myself(even though others love them) because they turn to rust in about a week.
Re: Aluminum heads and spark plugs [Re: GomangoCuda] #1583833
02/26/14 06:03 PM
02/26/14 06:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes this is nothing new, when I was racing I never shared tech like this.
I love when guys doubt you and you go out beat there azzes on the track.
Re: Aluminum heads and spark plugs [Re: jamesc] #1583834
02/26/14 06:08 PM
02/26/14 06:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
I can tell you never raced with a super charger, a super charged engine needs every edge you can give it because it's on the ragged edge, it's where I live.
In alcohol racing MSD techs came around to each alcohol team using MSD to help us. We listened and did what they suggested. So did many other venders because we are the one's spending $$.
Page 2 of 3 1 2 3
