hILBORN FUEL INJECTION - What does it fit ? #1582740
02/23/14 03:27 AM
02/23/14 03:27 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
I bought this HILBORN FUEL INJECTION unit at an auction today and cannot find a lot of info. on what it might fit. It is 2 separate manifolds that look like a BB Chrysler and the only numbers on the manifolds are 331-C-8. Any help would be great.
JW
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: jwmotors] #1582741
02/23/14 03:43 AM
02/23/14 03:43 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
how about some side shots of the ports.
I am truckless..
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: jwmotors] #1582742
02/23/14 03:57 AM
02/23/14 03:57 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
If I was to guess, I would say that would fit the first 331 CID Hemis for the 1951 models
Hope you did not pay to much...I have seen auction fever and it can be scary
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: Polarapete] #1582743
02/23/14 05:04 AM
02/23/14 05:04 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's not for a hemi of any kind...
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: Jim_Lusk] #1582744
02/23/14 09:31 AM
02/23/14 09:31 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
331 Cadillac (& 365/390)
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: 6bblgt] #1582745
02/23/14 09:32 AM
02/23/14 09:32 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: 6bblgt] #1582746
02/23/14 09:48 AM
02/23/14 09:48 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
sure would like to put a hilborn set up on my Hemi car!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: BB65Barracuda] #1582747
02/23/14 10:04 AM
02/23/14 10:04 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
Here is a bottom view
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: jwmotors] #1582748
02/23/14 10:22 AM
02/23/14 10:22 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
Looking at the pictures I have found I do not think it is a Hemi, the Hemis tubes are spaced evenly apart. The BB units are grouped together.
The ports are not MAX WEDGE size. As for price I go to at least one auction a week, there are a lot here in NC. Sometimes you pay to much sometimes you get a steal. In my experience I have been able to buy a lot of hard to find items ( auto parts is mostly what I look for )and tools that you would never be able to buy if the owner was still alive.
The junkier the sale generally the better. They had the fuel injection unit paired up with a factory GM intake for a 62 fuel injected Vette What are the odds of finding that under some guys tool bench ?
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: jwmotors] #1582749
02/23/14 11:29 AM
02/23/14 11:29 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Just found this on the bag.....Hilborn 331-CH-80 440 Chrysler. Being it is basically the same # minus the H and 0, could it be a predecessor? Possibly.
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: jwmotors] #1582750
02/23/14 11:29 AM
02/23/14 11:29 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
It's CADILLAC - here's a 4-71 intake I used to own & block/head surface position.
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: 70HemiGTX] #1582751
02/23/14 11:47 AM
02/23/14 11:47 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
I saw that on E bay Looks pretty similar , number is close. Mine the mounting flanges are not cut like BB intakes. Like you said though it could be a early version. A Caddy is possible,
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: 6bblgt] #1582752
02/23/14 02:45 PM
02/23/14 02:45 PM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
It's CADILLAC - here's a 4-71 intake I used to own & block/head surface position. [/quote 6bblgt your right looks like it is a Caddy. Pulled up a picture of a 1953 331 intake gasket and it had the holes for I assume is a locating dowel ? Thanks for your input. I guess the C means Caddy and the CH means Chrysler.
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: jwmotors] #1582753
02/23/14 04:12 PM
02/23/14 04:12 PM
Call Mike Chilando at Alkydiggers in Nashville--he will make you an offer on the spot--it is not worth as much as you think but still way cool and rare so...Mike is straight up guy I bought the one pictured complete with pump for $600 at a big well attended show--it takes about $1000 more to get a good pump, plumbing, nozzles etc so it is a Long way from running again--hose sets are over $150 FWIW
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: jwmotors] #1582754
02/23/14 10:02 PM
02/23/14 10:02 PM
I would measure the port width and height to see if it is a 440, M.W.or B1 port size Looking at the first picture it looks like this unit is a cast magneiseum (SP?) unit, not aluminum Call them and ask the source, there really good folks to deal with Those early tubelar mechanical F.I. unit converted to EFI works great at the track and on the street
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: Cab_Burge] #1582755
02/23/14 10:45 PM
02/23/14 10:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I have a nice Enderle setup for a 289/302 Ford..
I am truckless..
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: 340SHORTY] #1582756
02/24/14 12:04 AM
02/24/14 12:04 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Looks like Cadillac, this is 331 Hemi Hilborn.
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: Bull1tt] #1582757
02/24/14 12:09 AM
02/24/14 12:09 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
BB Mopar wedge engine Hilborn unit.
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: Bull1tt] #1582758
02/24/14 12:14 AM
02/24/14 12:14 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Compare yours to the post above
Re: hILBORN FUEL INJECTION - What does it fit ? [Re: Bull1tt] #1582759
02/24/14 12:27 AM
02/24/14 12:27 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
Thanks for the help Bull1tt, It is for a Cadilac as pointed out by you and 6bblgt . Looks like the Caddy stuff is non-existent , which from a selling the selling end is good,
