Re: hILBORN FUEL INJECTION - What does it fit ?
[Re: jwmotors]
#1582741
02/23/14 03:43 AM
02/23/14 03:43 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
how about some side shots of the ports.
I am truckless..
[Re: Polarapete]
#1582743
02/23/14 05:04 AM
02/23/14 05:04 AM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
If I was to guess, I would say that would fit the first 331 CID Hemis for the 1951 models
Hope you did not pay to much...I have seen auction fever and it can be scary
It's not for a hemi of any kind...
[Re: BB65Barracuda]
#1582747
02/23/14 10:04 AM
02/23/14 10:04 AM
Posts: 108 NC
jwmotors
NC
[Re: 70HemiGTX]
#1582751
02/23/14 11:47 AM
02/23/14 11:47 AM
Posts: 108 NC
jwmotors
NC
Just found this on the bag.....Hilborn 331-CH-80 440 Chrysler. Being it is basically the same # minus the H and 0, could it be a predecessor? Possibly.
I saw that on E bay Looks pretty similar , number is close. Mine the mounting flanges are not cut like BB intakes. Like you said though it could be a early version. A Caddy is possible,
[Re: 6bblgt]
#1582752
02/23/14 02:45 PM
02/23/14 02:45 PM
Posts: 108 NC
jwmotors
NC
It's CADILLAC - here's a 4-71 intake I used to own & block/head surface position. [/quote 6bblgt your right looks like it is a Caddy. Pulled up a picture of a 1953 331 intake gasket and it had the holes for I assume is a locating dowel ? Thanks for your input. I guess the C means Caddy and the CH means Chrysler.
[Re: jwmotors]
#1582753
02/23/14 04:12 PM
02/23/14 04:12 PM
Call Mike Chilando at Alkydiggers in Nashville--he will make you an offer on the spot--it is not worth as much as you think but still way cool and rare so...Mike is straight up guy I bought the one pictured complete with pump for $600 at a big well attended show--it takes about $1000 more to get a good pump, plumbing, nozzles etc so it is a Long way from running again--hose sets are over $150 FWIW
[Re: Cab_Burge]
#1582755
02/23/14 10:45 PM
02/23/14 10:45 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I have a nice Enderle setup for a 289/302 Ford..
I am truckless..
