600/625 on a 440 #1580586
02/18/14 02:02 AM
02/18/14 02:02 AM
Iowa
76dodgeboy Offline OP
Iowa
Would a 600 Eddy or 625 Carter be too small for a 440?
Re: 600/625 on a 440 [Re: 76dodgeboy] #1580587
02/18/14 02:29 AM
02/18/14 02:29 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I've ran a few 600 edelbrocks on 440s that were mostly stock other than headers and a summit cam.
Great response and mpg, I got no complaints.
I prefer a TQ but people keep selling me edelbrocks for less than what a TQ rebuild kit costs.
Re: 600/625 on a 440 [Re: Diplomat440] #1580588
02/18/14 02:32 AM
02/18/14 02:32 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
My dads old 67 New Yorker had a factory 1850 625 CFM Holley on it from the factory..
I am truckless..
Re: 600/625 on a 440 [Re: 340SHORTY] #1580589
02/18/14 03:41 AM
02/18/14 03:41 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Wasn't the factory Carter AVS used on 440 Magnum engines a 580 CFM ? The 340 used a 480 CFM. No wonder they made more power when a Holley 750 was swapped on !
Re: 600/625 on a 440 [Re: Kern Dog] #1580590
02/18/14 03:48 AM
02/18/14 03:48 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Frankie, the '71 340 OEM carb was an 850 TQ...
Re: 600/625 on a 440 [Re: RSNOMO] #1580591
02/18/14 03:51 AM
02/18/14 03:51 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
OOOoof !
I should have said the 68-70 !
Re: 600/625 on a 440 [Re: Kern Dog] #1580592
02/18/14 04:41 AM
02/18/14 04:41 AM
Iowa
Iowa
I was told that All Mopar engines run better with smaller carbsquare. Same guy said a 650 was too big for a 318. Important not looking to make power. Its a W200 Clubcab Longbox. Has Headers on it. Better Mileage would be Sweet lol
Re: 600/625 on a 440 [Re: Kern Dog] #1580593
02/18/14 05:04 AM
02/18/14 05:04 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nope, Scott can probably add more, but the 440 HP AVS was a 750 and the 340 ran a 625...
Re: 600/625 on a 440 [Re: Jim_Lusk] #1580594
02/18/14 05:20 AM
02/18/14 05:20 AM
The Lo Po BB got the smaller Holley vacune secondary carbs.
Re: 600/625 on a 440 [Re: 76dodgeboy] #1580595
02/18/14 11:29 AM
02/18/14 11:29 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It will work but what is the vehicle being used for?
Coming soon!!!!
Re: 600/625 on a 440 [Re: Mr.Yuck] #1580596
02/18/14 11:45 AM
02/18/14 11:45 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You're the carb expert, you tell us.
In case/when Yuck gets it wrong. Yes it will work fine.
Max carb size is only relevant for max HP/RPM efforts. You are almost always better off choosing a smaller carb than a larger one.
Don't be the exception.
Re: 600/625 on a 440 [Re: Supercuda] #1580597
02/18/14 12:12 PM
02/18/14 12:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had a Carter comp series 625 on a mostly stock 67 GTX (CH4B intake and small cam) it ran good. 13.86 thru the logs 2 1/4 exhaust, 3.55's on BFG's.. loved that car.
Re: 600/625 on a 440 [Re: Mr.Yuck] #1580598
02/18/14 12:21 PM
02/18/14 12:21 PM
dogdays Offline
dogdays  Offline
A Holley 1850 is, and always has been, a 600 cfm carb.
A Holley 1850 was never stock on any Chrysler engine. There were other Holleys that filled that role.
R.
Re: 600/625 on a 440 [Re: 76dodgeboy] #1580599
02/18/14 12:23 PM
02/18/14 12:23 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
For optimum performance it is on the small side, for general street use it will be fine and have good torque, high velocity and excellent throttle response.
Smaller is usually better on a street cruiser. On my 5.9/360 in the Duster it would pull a vacuum at WOT with a 625 cfm though which is a good indication it was undercarb'd.
Was as I now have a 750 on it.
If you have the 600/625 run it, won't cost you anything or hurt anything and you can always upgrade later if looking for "more"
"I think its got a hemi"
Re: 600/625 on a 440 [Re: gdonovan] #1580600
02/18/14 12:42 PM
02/18/14 12:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did a little impromptu testing on my 87 Diplomat, 360, A833, 2.94 rear.
Ran an Ebrock 600 and an Ebrock 750. Numberswise, the smaller carb netted me low 20's for mileage and topped out at 115 mph. Larger carb netted me high teens for mileage and would peg the 125 mph cop speedo.
For the intangibles, the smaller carb felt more responsive, the larger felt somewhat lazy in comparison.
I did not optimize the tunes either, I might have picked a bit up but who knows. Since I did not regularly haul around at 115+ and was commuting 75 miles each way to work I kept the smaller carb on the engine. But that engine was not setup for high rpm running anyway. Comp XE262 cam, Performer intake, 302 heads, stock 3 cat exhaust.
Re: 600/625 on a 440 [Re: Supercuda] #1580601
02/18/14 12:54 PM
02/18/14 12:54 PM
Ran an Ebrock 600 and an Ebrock 750. Numberswise, the smaller carb netted me low 20's for mileage and topped out at 115 mph. Larger carb netted me high teens for mileage and would peg the 125 mph cop speedo.For the intangibles, the smaller carb felt more responsive, the larger felt somewhat lazy in comparison.
Good stuff (especially the "more responsive") . OP, it sounds like you have a 600/625 on hand, run it & go from there
Re: 600/625 on a 440 [Re: RapidRobert] #1580602
02/18/14 01:38 PM
02/18/14 01:38 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Nope......
Heck, A 440 can even run on a 2 barrel, but it wont make optimum power..GM understood this as most of their big inch motors had 800 cfm Q jets (and performance cars had 780 Holleys)..Heck they even put a 780 on a dinky 302 Z28!
Dont believe me?
Take a stone stock 440HP 4V...Take off that crappy little AVS and bolt on a "new" 800CFM Edelbrock Thunder Series AVS and make no other mods...Night and day difference
MB
Re: 600/625 on a 440 [Re: HPMike] #1580603
02/18/14 08:52 PM
02/18/14 08:52 PM
Iowa
Iowa
Thanks forth responses. Its a W200 Clubcab. has the factory carb but visually can see its wet just sitting. I have an eddy 600 and a Carter 625. Hp383 Will be tossing a kit in one for me. It will be driven at least 60 miles a day if it gets ok mileage bit granted Most all 70s W200s had 4 1 gears. I'll save up for a 750 as the truck may end up a parts etc hauler
Re: 600/625 on a 440 [Re: 76dodgeboy] #1580604
02/19/14 12:01 AM
02/19/14 12:01 AM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
I used to have a mild (stock) rebuilt '69 440
in a C body Chrysler. The cam was the Mopar
.455 lift hydralic,stock 906 heads with just a 3 angle valve job, 1-7/8 headers,CH4B intake,
and a Carter 625 4 bbl. The car would fall flat
in the upper (5,000) rpm range and run out of steam.
I went back in it a year later, changed to the
.509 cam, put a Holley 3310 750 4bbl on it, and it was a completely different car! Took it to
a local track and did a best of 14.10 @101mph
After that I always stuck with the Holley.
Plymouth Makes It!
Re: 600/625 on a 440 [Re: RoadRunnerLuva] #1580605
02/19/14 01:40 AM
02/19/14 01:40 AM
Iowa
Iowa
Its a truck so it probably won't see bit maybe 4000rpm. Im just leary of spending the cash to have hp go Through the stock carb and the body be warped or end of cracking. Im sure I'll upsized to a 750 later
