Why do I squeak going around corners? #1580433
02/17/14 08:17 PM
02/17/14 08:17 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
OK guys, im kinda lost on this one.
I have recently had an 8-3/4 installed in my Dakota. And I am at 75 miles since the install, and it was finally warm enough to roll down the windows.
I noticed a "squeak, squeak, squeak" noise coming from the rear of the truck when turning.
So I pulled into a parking lot and did some slow tight figure 8's, and the sound is coming from each wheel area (the squeak seems to be coming from the inside radius wheel).
I rolled into the shop and they double checked all clearances, and made sure u bolts were tight, even tore things down and removed the brakes for a quick inspection of the new parts in there as well. Nothing looked out of place, or seemed to show any signs of trouble.
They reinstalled and we ran it on the lift, no noises, no odd vibrations.
The current thought is that perhaps the wide tires, and the suregrip, with the relatively short wheel base, are causing some deflection in the steel 8" (Cragar soft 8) wheels, thus making the squeaky sound.
Is this plausible? Tires are Cooper Cobra 295/50/15 on the 8" wide Cragar Soft 8 wheel. (should I look at switching to the 10" wide wheel to better fit the wide tire?)
Axles are Dutchman with green bearings
Rear is a cone style suregrip
I can learn to live with the squeak, its not that noticeable, I just would like to be sure I'm not missing a larger issue.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Why do I squeak going around corners? [Re: hp383] #1580434
02/17/14 08:40 PM
02/17/14 08:40 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
Re: Why do I squeak going around corners? [Re: hp383] #1580435
02/17/14 09:17 PM
02/17/14 09:17 PM
I would think from too much axle end play tho I ain't sure how you would reduce that with greens
Re: Why do I squeak going around corners? [Re: hp383] #1580436
02/17/14 09:56 PM
02/17/14 09:56 PM
Kirkland, Washington
Pacnorthcuda Offline
Is it simply tire binding from a tight sure grip? If you try on a loose or wet surface it should've obvious.
Re: Why do I squeak going around corners? [Re: Pacnorthcuda] #1580437
02/17/14 10:16 PM
02/17/14 10:16 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
yes when turning on snow that same day, there was no squeak, However there were not enough places to test this due to the warm weather. On the gravel parking lot, there is too much noise to hear if anything is squeaking.
It still has me wondering if its the rim flexing, or something else.
I have had tight sure grips cause wheel squeal, or chirping, and even had a few really snug ones result in vibration, but this is not the same sort of sound, and no noticeable vibration.
This is like a metal to metal sort of squeaking. Really light sound, and changes with wheel rotation speed.
Re: Why do I squeak going around corners? [Re: hp383] #1580438
02/17/14 10:46 PM
02/17/14 10:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is it only when you turn ? I can tell you I have driven alot of trucks over the years (Dodge tech for 23 years) and many of them with some miles on them would squeak from the rear and it was really noted riding next to a building. Most of the time it was out of round drums touching the brakes shoes at the drum high spots. Some were worse on turns because the rim does flex a tad on turns as I also had front disc do the same and many times you could only hear the disc on turns when the rim rotor flex a tad. Ron
Re: Why do I squeak going around corners? [Re: 383man] #1580439
02/17/14 11:34 PM
02/17/14 11:34 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I suppose it could be the drum rubbing slighty on the brakes. It has all new brake parts, and shoes, one new drum (one got ruined in bearing failure) and one existing drum.
Drums were turned at same shop to be sure they were round.
Maybe the 75 miles hasn't given the fresh cut drum, and new shoes time to settle in to a pattern yet.
Brakes are adjusted correctly, but maybe the shoes have some high spots or something along the edges.
Re: Why do I squeak going around corners? [Re: hp383] #1580440
02/17/14 11:47 PM
02/17/14 11:47 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
And yes, it is only making noise on corners. I used the drive by a building trick to see if it made any noise while driving straight. I have used that trick many a time to find a noise.
Re: Why do I squeak going around corners? [Re: hp383] #1580441
02/17/14 11:47 PM
02/17/14 11:47 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
There HAS to be a new title for someone with that thread title.
Dennis
Re: Why do I squeak going around corners? [Re: cudaboy] #1580442
02/18/14 12:19 AM
02/18/14 12:19 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I agree with Ron on this.
Make sure the axle flange has zero run out as well.
Re: Why do I squeak going around corners? [Re: Todd] #1580443
02/18/14 09:12 AM
02/18/14 09:12 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Check pinion angle and possible rear u joint yoke contact. I had this when I changed a set of ss springs with a slightly shorter front segment. Had a squeal at low speed going around corners and thought the drive shaft was bottoming out in the tranny, so shortened it and still had it. Looking things over a friend thought the pinion angle looked wrong so changed it with shims and that took care of it
Re: Why do I squeak going around corners? [Re: cudaboy] #1580444
02/18/14 04:16 PM
02/18/14 04:16 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Dennis
I'm not worried, I usually fly under the Modar
Re: Why do I squeak going around corners? [Re: hp383] #1580445
02/18/14 04:17 PM
02/18/14 04:17 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
oops... that was unbelievably fast... one minute and bam!
so much for being off the Modar... How do they know?
Re: Why do I squeak going around corners? [Re: hp383] #1580446
02/18/14 04:46 PM
02/18/14 04:46 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
try COASTING around your figure 8. Then try again with slight power on, then with a little more power on. If it squeaks only with power on it's the new/tight sure grip. My car does it now and then when only slight power on, never when coasting around a turn.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Why do I squeak going around corners? [Re: amxautox] #1580447
02/18/14 07:31 PM
02/18/14 07:31 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
What about polyurethane bushings in your rear suspension. Were those swapped out? That was the cause of my squeaking and I replaced them with rubber
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
