Why do I squeak going around corners?
#1580433
02/17/14 08:17 PM
02/17/14 08:17 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
OK guys, im kinda lost on this one.
I have recently had an 8-3/4 installed in my Dakota. And I am at 75 miles since the install, and it was finally warm enough to roll down the windows.
I noticed a "squeak, squeak, squeak" noise coming from the rear of the truck when turning.
So I pulled into a parking lot and did some slow tight figure 8's, and the sound is coming from each wheel area (the squeak seems to be coming from the inside radius wheel).
I rolled into the shop and they double checked all clearances, and made sure u bolts were tight, even tore things down and removed the brakes for a quick inspection of the new parts in there as well. Nothing looked out of place, or seemed to show any signs of trouble.
They reinstalled and we ran it on the lift, no noises, no odd vibrations.
The current thought is that perhaps the wide tires, and the suregrip, with the relatively short wheel base, are causing some deflection in the steel 8" (Cragar soft 8) wheels, thus making the squeaky sound.
Is this plausible? Tires are Cooper Cobra 295/50/15 on the 8" wide Cragar Soft 8 wheel. (should I look at switching to the 10" wide wheel to better fit the wide tire?)
Axles are Dutchman with green bearings
Rear is a cone style suregrip
I can learn to live with the squeak, its not that noticeable, I just would like to be sure I'm not missing a larger issue.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Why do I squeak going around corners?
[Re: hp383]
#1580435
02/17/14 09:17 PM
02/17/14 09:17 PM
RapidRobert
I would think from too much axle end play tho I ain't sure how you would reduce that with greens
[Re: Pacnorthcuda]
#1580437
02/17/14 10:16 PM
02/17/14 10:16 PM
hp383
State of Confusion
yes when turning on snow that same day, there was no squeak, However there were not enough places to test this due to the warm weather. On the gravel parking lot, there is too much noise to hear if anything is squeaking.
It still has me wondering if its the rim flexing, or something else.
I have had tight sure grips cause wheel squeal, or chirping, and even had a few really snug ones result in vibration, but this is not the same sort of sound, and no noticeable vibration.
This is like a metal to metal sort of squeaking. Really light sound, and changes with wheel rotation speed.
[Re: 383man]
#1580439
02/17/14 11:34 PM
02/17/14 11:34 PM
hp383
State of Confusion
I suppose it could be the drum rubbing slighty on the brakes. It has all new brake parts, and shoes, one new drum (one got ruined in bearing failure) and one existing drum.
Drums were turned at same shop to be sure they were round.
Maybe the 75 miles hasn't given the fresh cut drum, and new shoes time to settle in to a pattern yet.
Brakes are adjusted correctly, but maybe the shoes have some high spots or something along the edges.
[Re: hp383]
#1580440
02/17/14 11:47 PM
02/17/14 11:47 PM
hp383
State of Confusion
And yes, it is only making noise on corners. I used the drive by a building trick to see if it made any noise while driving straight. I have used that trick many a time to find a noise.
[Re: hp383]
#1580445
02/18/14 04:17 PM
02/18/14 04:17 PM
hp383
State of Confusion
oops... that was unbelievably fast... one minute and bam!
so much for being off the Modar... How do they know?
[Re: hp383]
#1580446
02/18/14 04:46 PM
02/18/14 04:46 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
try COASTING around your figure 8. Then try again with slight power on, then with a little more power on. If it squeaks only with power on it's the new/tight sure grip. My car does it now and then when only slight power on, never when coasting around a turn.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1580447
02/18/14 07:31 PM
02/18/14 07:31 PM
Posts: 5,890 Athens, Greece
Pyper70
Athens, Greece
What about polyurethane bushings in your rear suspension. Were those swapped out? That was the cause of my squeaking and I replaced them with rubber
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
