426 Hemi engine wiring harness #1580038
02/16/14 10:22 PM
02/16/14 10:22 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Curious.. I just got my engine harness for my 426 Hemi, application 1969 Dodge Charger Daytona. Well, I laid it out over the motor/valve cover and noticed there wasn't a connection for the oil pressure sending unit... Is it different on a hemi car or did M&H just mess up?
Cheers,
Troy
Troy
Houston Mopar Connection Club
Re: 426 Hemi engine wiring harness [Re: hemi68charger] #1580039
02/16/14 10:34 PM
02/16/14 10:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It is on a 71, just might be for a 69. Look at the book to see what it says also.
Re: 426 Hemi engine wiring harness [Re: 71birdJ68] #1580040
02/16/14 11:27 PM
02/16/14 11:27 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
The oil pressure wire is part of the positive battery cable, as is the neutral safety/backup light harness. Hence the reason HEMI positive cables are so expensive.
Re: 426 Hemi engine wiring harness [Re: Paul Jacobs] #1580041
02/17/14 01:03 AM
02/17/14 01:03 AM
Houston, Tx
Houston, Tx
Taaa Daaa !!!
OK, now I will go out and check my new "expensive" positive cable I got a few weeks ago..
Thanks Paul...
Yeap, I see it now........ Just went out to the garage and looked at the cable.......
Troy
Re: 426 Hemi engine wiring harness [Re: hemi68charger] #1580042
02/17/14 03:24 AM
02/17/14 03:24 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just a question, did the 69s have a special resistance wire that went from the sending unit to the wiring harness? The 71s did just curious.
