426 Hemi engine wiring harness
#1580038
02/16/14 10:22 PM
02/16/14 10:22 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang..
Curious.. I just got my engine harness for my 426 Hemi, application 1969 Dodge Charger Daytona. Well, I laid it out over the motor/valve cover and noticed there wasn't a connection for the oil pressure sending unit... Is it different on a hemi car or did M&H just mess up?
Cheers, Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 426 Hemi engine wiring harness
[Re: Paul Jacobs]
#1580041
02/17/14 01:03 AM
02/17/14 01:03 AM
hemi68charger
Houston, Tx
The oil pressure wire is part of the positive battery cable, as is the neutral safety/backup light harness. Hence the reason HEMI positive cables are so expensive.
Taaa Daaa !!!
OK, now I will go out and check my new "expensive" positive cable I got a few weeks ago..
Thanks Paul...
Yeap, I see it now........ Just went out to the garage and looked at the cable.......
