All narrowed up!! pix included #1579560
02/15/14 11:07 PM
02/15/14 11:07 PM
Finally a HUSKER again
Moparnut426 Offline OP
Was a success!! Got it all cut down, tacked up, mocked in the car, checked tire clearance, that was a go, so I welded it up full. I welded it in quadrants. I checked to make sure the shaft spun after every weld. Spun fine, Had a little resistance, but it stayed even and OI let it col completely and its cooling in my shop on the jig.
im planing on stock ride height and planning on buying a better shock than the ranchos. does anyone here know the shock part number for a QA1 adjustable shock with stock rde height?
Re: All narrowed up!! [Re: Moparnut426] #1579561
02/16/14 09:37 PM
02/16/14 09:37 PM
here are a few pixs of the rearend both on the the jog and in the car as a mock up.
Re: All narrowed up!! [Re: Moparnut426] #1579562
02/16/14 09:39 PM
02/16/14 09:39 PM
Re: All narrowed up!! [Re: Moparnut426] #1579563
02/16/14 09:40 PM
02/16/14 09:40 PM
2
Re: All narrowed up!! [Re: Moparnut426] #1579564
02/16/14 09:42 PM
02/16/14 09:42 PM
3
you can see how far off the housing was its about 1/8" off set
Re: All narrowed up!! [Re: Moparnut426] #1579565
02/16/14 09:43 PM
02/16/14 09:43 PM
jog is really adjustable so i can do danas to its plenty far above the table.
Re: All narrowed up!! [Re: Moparnut426] #1579566
02/16/14 09:46 PM
02/16/14 09:46 PM
a lot better tire clearance to!!
Re: All narrowed up!! [Re: Moparnut426] #1579567
02/16/14 09:49 PM
02/16/14 09:49 PM
welds turned out ok, I just turned up the ol miller and burned it in hot.
Re: All narrowed up!! [Re: Moparnut426] #1579568
02/16/14 09:52 PM
02/16/14 09:52 PM
all blasted up, just have to tap a hole for a drain and its done, except for the obvious welding and wrapping the perches.
Re: All narrowed up!! [Re: Moparnut426] #1579569
02/16/14 09:52 PM
02/16/14 09:52 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: All narrowed up!! [Re: 1967dartgt] #1579570
02/16/14 10:35 PM
02/16/14 10:35 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
looking good. might have to send you my dana 60 to get shorend etc.great job. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: All narrowed up!! [Re: Moparnut426] #1579571
02/16/14 10:51 PM
02/16/14 10:51 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What tire size is that?
Re: All narrowed up!! [Re: 1967dartgt] #1579572
02/16/14 11:01 PM
02/16/14 11:01 PM
295-55-15
Re: All narrowed up!! [Re: Moparnut426] #1579573
02/16/14 11:14 PM
02/16/14 11:14 PM
parma,ohio
66littlebigmopar Offline
parma,ohio
Looks good, I just did my housing made the pucks at work and got the bar. Its amazing how easy it was, all ways seemed like a black science to me should have done them long ago myself live and learn.
Re: All narrowed up!! [Re: Moparnut426] #1579574
02/17/14 12:06 AM
02/17/14 12:06 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Those are some very good looking welds
I have a Miller 211 and I need some more practice before mine look that good
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: All narrowed up!! [Re: Polarapete] #1579575
02/17/14 12:11 AM
02/17/14 12:11 AM
thank you for that. ive been around a welder a time or two.
Re: All narrowed up!! [Re: Moparnut426] #1579576
02/17/14 11:50 PM
02/17/14 11:50 PM
South Dakota
hotairballoonpilot Offline
South Dakota
Looks good Kasey!
Contact Me about AMD Prices
Re: All narrowed up!! [Re: hotairballoonpilot] #1579577
02/18/14 01:49 AM
02/18/14 01:49 AM
thanks Corey.
Re: All narrowed up!! [Re: Moparnut426] #1579578
02/18/14 01:52 AM
02/18/14 01:52 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Looks like the housing was bent fairly bad. Anymore you would have had to straighten so you would have something to weld to. Get one out of a truck and you will have to straighten it first.
Also you should recheck for straightness after you weld on the perches. I usually weld the perches on before the new ends are finish welded. Rearend and jig looks good. Nice work
Re: All narrowed up!! [Re: qwkmopardan] #1579579
02/18/14 02:09 AM
02/18/14 02:09 AM
thank you.
