All narrowed up!! pix included
#1579560
02/15/14 11:07 PM
02/15/14 11:07 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Was a success!! Got it all cut down, tacked up, mocked in the car, checked tire clearance, that was a go, so I welded it up full. I welded it in quadrants. I checked to make sure the shaft spun after every weld. Spun fine, Had a little resistance, but it stayed even and OI let it col completely and its cooling in my shop on the jig.
im planing on stock ride height and planning on buying a better shock than the ranchos. does anyone here know the shock part number for a QA1 adjustable shock with stock rde height?
Re: All narrowed up!!
[Re: Moparnut426]
#1579578
02/18/14 01:52 AM
02/18/14 01:52 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
you can see how far off the housing was its about 1/8" off set
Looks like the housing was bent fairly bad. Anymore you would have had to straighten so you would have something to weld to. Get one out of a truck and you will have to straighten it first.
Also you should recheck for straightness after you weld on the perches. I usually weld the perches on before the new ends are finish welded. Rearend and jig looks good. Nice work
