high spring pressure limit? #1577774
02/12/14 01:54 AM
02/12/14 01:54 AM
ca
brownout Offline OP
brownout  Offline OP
ca
what do you think the spring pressure limits are on a stock size cam bearing? when would it be recommended to upgrade to a larger roller bearing? looking to run atriple sping at 960 on the open side may be less with the new cam. already have fresh performance cam bearings in but looking to step up the power.
thanks cody
Re: high spring pressure limit? [Re: brownout] #1577775
02/12/14 02:35 AM
02/12/14 02:35 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
thanks cody
It's funny that you mention this as I was struggling with the same question last weekend. I came to the conclusion that the Manley 221425
spring with 2.100 installed height, 280 on the seat, and 800 open pressure should be the limit without a larger cam core. I personally don't think roller bearings are necessary. Others may have another opinion.
Re: high spring pressure limit? [Re: brownout] #1577776
02/12/14 03:02 AM
02/12/14 03:02 AM
ca
brownout Offline OP
brownout  Offline OP
ca
will a standard size billet core cam support that much open pressure? engine might will most likeley see 7500 to 8000 rpm.
thanks, Cody
Re: high spring pressure limit? [Re: brownout] #1577777
02/12/14 09:57 AM
02/12/14 09:57 AM
gregsdart Offline
gregsdart  Offline
I have been running 947 Comp triples on my 440-1 motor for a long time. They are 340 on the seat at 2.00. If you can control the valvetrain with a double spring that is lighter, you will be better off. The most rpm I have run is 7800 through the traps.
Re: high spring pressure limit? [Re: gregsdart] #1577778
02/13/14 01:54 AM
02/13/14 01:54 AM
ca
brownout Offline OP
brownout  Offline OP
ca
Thanks for the replies. Greg how long have you had your motor together with that combo? Doesn't seem to be much out there on this topic any info will help.
Thanks cody
Re: high spring pressure limit? [Re: brownout] #1577779
02/13/14 02:57 AM
02/13/14 02:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks cody
I cant really help you... my stuff(SB) uses a 50mm
core..springs are 320 seat but almost 900 open..
the engine has been to 9600 but didnt make any power
up there... lift is too small
Re: high spring pressure limit? [Re: MR_P_BODY] #1577780
02/14/14 04:28 AM
02/14/14 04:28 AM
ca
brownout Offline OP
brownout  Offline OP
ca
thanks mr p body sounds promising
Re: high spring pressure limit? [Re: brownout] #1577781
02/15/14 09:27 PM
02/15/14 09:27 PM
gregsdart Offline
gregsdart  Offline
I have over one hundred runs on the same set of springs. Can't say the same for all the rockers and lifters! The lifters have taken a beating and need to be watched religiously, checking lash for any change. I have had lifter failures and bought a new set, so I guess you could say average life with my deal has been 50 passes? The loads really stress the rockers as well. I have hurt a fair amount of rocker axles and bearings on the Jesel stuff, due to needle bearing cage failures. These bearings were hurt by the rockers slamming sideways and crushing the cages, leading to stuck needles, then galled shafts. I have since changed the way those rockers are held in place and have eliminated the C clips that take the beating.
I don't put a lot of runs per year on my stuff, so hopefully you will get more feedback.
If I had it to do over, I would have bought Ti intakes at least, and hollow stem valves as another option to save valvetrain weight. A high rocker ratio helps. The lifter and pushrod don't have to travel as far. There are better double springs now that work as well as the triples I have I believe, with less spring weight, and less total lbs of load needed both on the seat and open.
