what do you think the spring pressure limits are on a stock size cam bearing? when would it be recommended to upgrade to a larger roller bearing? looking to run atriple sping at 960 on the open side may be less with the new cam. already have fresh performance cam bearings in but looking to step up the power.
thanks cody
