What adhesive tape to attach the 'Cuda tailpanel emblem #1577708
02/11/14 11:40 PM
02/11/14 11:40 PM
South Carolina
sixpackbird Offline OP
South Carolina
What adhesive tape have you used to attach the 'Cuda tail panel emblem?
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: sixpackbird] #1577709
02/12/14 12:11 AM
02/12/14 12:11 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
It's been a long time but I'm pretty sure I put mine on with VERY carefully applied RTV silicone.
If you're using tape get the 3M stuff from an autobody supply store, it has a very aggressive adhesive..
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: sixpackbird] #1577710
02/12/14 12:18 AM
02/12/14 12:18 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I used body shop two sided tape. It's been on for 7 or 8 years now and still tight as a tick.
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: 5spdcuda] #1577711
02/12/14 01:09 PM
02/12/14 01:09 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The two sided emblem foam is the right way to go, but it will be painstaking to fit and trim to the back of the emblem.
Rather than buy a whole roll, you might hit up a body shop and see if they will spare you a couple feet of theirs. It comes in different widths and in gray and black.
Master, again and still
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: sixpackbird] #1577712
02/16/14 09:37 AM
02/16/14 09:37 AM
Maryland
glenngomango Offline
Maryland
I bought laser cut double sided tape ( cuda specific) on ebay a few months ago
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: glenngomango] #1577713
02/16/14 12:16 PM
02/16/14 12:16 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..if using 2 sided tape is there an easy way to remove it?
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: can.al] #1577714
02/16/14 01:23 PM
02/16/14 01:23 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
3M emblem adhesive?
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: can.al] #1577715
02/16/14 01:54 PM
02/16/14 01:54 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Other than chemicals, no it is sticky stuff and does it's job well. There is an orange wheel that is made to remove decals and the like, but it is not well suited to this task, IMO.
We use lacquer thinner to remove the adhesive after we have gotten the majority of the foam off.
Of course, be very careful with the solvents being suggested here, they can do a lot of damage, too.
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: glenngomango] #1577716
02/17/14 12:25 AM
02/17/14 12:25 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I thought I already posted this. I did the same thing two years ago. It has been out in the elements alot since it is a driver. There has been no issue whatsoever. I used goof off to clean the emblem before putting the tape on it.
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: denfireguy] #1577717
02/17/14 10:23 AM
02/17/14 10:23 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Do you have a link - I searched eBay and couldn't find the emblem-specific tape...
Re: What adhesive tape to attach the 'Cuda tailpanel emblem [Re: Gavin] #1577718
02/17/14 01:42 PM
02/17/14 01:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Go to Ebay, type in "cuda emblem sticker"...done
