Re: What adhesive tape to attach the 'Cuda tailpanel emblem
[Re: 5spdcuda]
#1577711
02/12/14 01:09 PM
02/12/14 01:09 PM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The two sided emblem foam is the right way to go, but it will be painstaking to fit and trim to the back of the emblem. Rather than buy a whole roll, you might hit up a body shop and see if they will spare you a couple feet of theirs. It comes in different widths and in gray and black.
Master, again and still
[Re: can.al]
#1577715
02/16/14 01:54 PM
02/16/14 01:54 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
..if using 2 sided tape is there an easy way to remove it?
Other than chemicals, no it is sticky stuff and does it's job well. There is an orange wheel that is made to remove decals and the like, but it is not well suited to this task, IMO.
We use lacquer thinner to remove the adhesive after we have gotten the majority of the foam off.
Of course, be very careful with the solvents being suggested here, they can do a lot of damage, too.
[Re: glenngomango]
#1577716
02/17/14 12:25 AM
02/17/14 12:25 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I bought laser cut double sided tape ( cuda specific) on ebay a few months ago
I thought I already posted this. I did the same thing two years ago. It has been out in the elements alot since it is a driver. There has been no issue whatsoever. I used goof off to clean the emblem before putting the tape on it.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Gavin]
#1577718
02/17/14 01:42 PM
02/17/14 01:42 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Do you have a link - I searched eBay and couldn't find the emblem-specific tape...
Go to Ebay, type in "cuda emblem sticker"...done
