Transmission problems #1575192
02/06/14 11:27 PM
02/06/14 11:27 PM
NORTH EAST TENNESSEE
hdrider927 Offline OP
I have a volare that had set a while got it running last weekend and all of a sudden it is hung in drive regardless of what gear you put it in or neutral any suggestion would be appreciated.
Re: Transmission problems [Re: hdrider927] #1575193
02/06/14 11:30 PM
02/06/14 11:30 PM
Kirkland, Washington
Pacnorthcuda Offline
Check to make sure the linkage is actually shifting the selector shaft.
Re: Transmission problems [Re: Pacnorthcuda] #1575194
02/07/14 01:11 AM
02/07/14 01:11 AM
it is must be internal
Re: Transmission problems [Re: hdrider927] #1575195
02/07/14 04:56 AM
02/07/14 04:56 AM
Louisville, Ky.
Mojoluv Offline
Mojoluv  Offline
Louisville, Ky.
Make sure the shift linkage that slides down over the valvebody is tight and not just moving back and forth. If it is tight, pull the valve body and make sure its not broken and working freely or replace it.
Re: Transmission problems [Re: hdrider927] #1575196
02/07/14 04:16 PM
02/07/14 04:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are you saying it drives forward even in Neutral? Does it lock up in Reverse? If so, the rear clutch isn't releasing; have to pull the trans to fix.
Re: Transmission problems [Re: John_Kunkel] #1575197
02/09/14 01:14 AM
02/09/14 01:14 AM
it will pull forward even in reverse if you rev it i pulled the valve body today dont see anything that shows to be wrong.
Re: Transmission problems [Re: hdrider927] #1575198
02/09/14 05:45 PM
02/09/14 05:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
While the VB is out, air test the rear clutch.
Re: Transmission problems [Re: hdrider927] #1575199
02/19/14 04:46 AM
02/19/14 04:46 AM
Partridge, KY
Hoop Offline
Hoop  Offline
Partridge, KY
I'm thinking rear planet gear set or reverse band!
Re: Transmission problems [Re: Hoop] #1575200
02/20/14 05:01 PM
02/20/14 05:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You're thinking wrong.
Re: Transmission problems [Re: John_Kunkel] #1575201
02/20/14 06:09 PM
02/20/14 06:09 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Those Belleville springs in the rear clutch can and do break. When mine did it jammed up the works and I had the same issue you're describing, it wanted to drive forward in neutral. Upon tear down I found this springs remnants jamming the clutches together enough to cause it not to release 100%.
Re: Transmission problems [Re: John_Kunkel] #1575202
02/20/14 07:55 PM
02/20/14 07:55 PM
Partridge, KY
Hoop Offline
Hoop  Offline
Partridge, KY
My reverse went out on mine, it pulled good in drive & 2, & I can't remember what it did in low it would pull a little forward even in reverse if you rev it, but I think it was just from rev. it up, but best I remember the gear shift did not lock up at first like his did, so yell it may not be, but when I got mine redone, it needed a rear gear set, reverse drum & reverse band!!..& reverse is accomplished by using only the rear gear set!
