Re: Transmission problems
[Re: hdrider927]
#1575196
02/07/14 04:16 PM
02/07/14 04:16 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Are you saying it drives forward even in Neutral? Does it lock up in Reverse? If so, the rear clutch isn't releasing; have to pull the trans to fix.
[Re: hdrider927]
#1575198
02/09/14 05:45 PM
02/09/14 05:45 PM
John_Kunkel
Rio Linda, CA
While the VB is out, air test the rear clutch.
[Re: hdrider927]
#1575199
02/19/14 04:46 AM
02/19/14 04:46 AM
Posts: 489 Partridge, KY
Hoop
Partridge, KY
it will pull forward even in reverse if you rev it i pulled the valve body today dont see anything that shows to be wrong.
I'm thinking rear planet gear set or reverse band!
[Re: John_Kunkel]
#1575202
02/20/14 07:55 PM
02/20/14 07:55 PM
Hoop
Partridge, KY
My reverse went out on mine, it pulled good in drive & 2, & I can't remember what it did in low it would pull a little forward even in reverse if you rev it, but I think it was just from rev. it up, but best I remember the gear shift did not lock up at first like his did, so yell it may not be, but when I got mine redone, it needed a rear gear set, reverse drum & reverse band!!..& reverse is accomplished by using only the rear gear set!
