Page 2 of 3 1 2 3
Re: '69 440 Valve Cover marking - See Pic [Re: FJ5_Fish] #1570852
01/31/14 02:55 PM
01/31/14 02:55 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
And here is the Engine Assy number.
Re: '69 440 Valve Cover marking - See Pic [Re: FJ5_Fish] #1570853
01/31/14 03:09 PM
01/31/14 03:09 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
Found the pics from my Doc-Tona. 440 Auto. This one has a "5" for the auto trans...
Ok, my mystery solved for the "916" and the "5". Any ideas what the markings on the rear of the drivers side valve cover as I posted above? Thanks, Mike
Re: '69 440 Valve Cover marking - See Pic [Re: MCTPhoenix] #1570854
01/31/14 04:21 PM
01/31/14 04:21 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Looks to me like an arrow pointing to where the throttle pressure linkage would be installed...
Re: '69 440 Valve Cover marking - See Pic [Re: FJ5_Fish] #1570855
01/31/14 10:15 PM
01/31/14 10:15 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
The 3 digit engine number is the last 3 numbers of the part number for that Engine Assembly. On the other side....an automatic trans equipped car would get either a 5, a 25 or a 125 depending on year etc.
Interesting...thanks. Any idea what number one should find on a 69 A12 automatic car? Should it be the same as a 4bbl car?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '69 440 Valve Cover marking - See Pic [Re: 69CoronetRT] #1570856
01/31/14 10:21 PM
01/31/14 10:21 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Good question. The A12 engines had some special features such as engine wire harness, valves, valve springs, distributor...not to mention intake and carbs. The 5600 mile automatic survivor Bee on the A12 website does have the number 5 on the driver's side but the number on the passenger side is smudged. It looks like a 950? However, the last 3 on my broadcast sheet engine number is 926 and it's an A12 automatic. I would think the number on the valve cover should read 926?
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570857
01/31/14 11:19 PM
01/31/14 11:19 PM
Ah, thats right. Forgot it got a different carb fro cars with A/C. That makes sense now!
Re: '69 440 Valve Cover marking - See Pic [Re: RoadRunnerJD] #1570858
02/01/14 12:03 AM
02/01/14 12:03 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
926 are the last three digits for a 383 automatic with a heater. That's on the fender tag of an A12 because the 440 replaced the 383 as the 440 was part of the A12 option package. The A12 is on the fender tag to indicate what other "options" were to be added.
The OP's 916 should also be on the fender tag if the OP has one?
Re: '69 440 Valve Cover marking - See Pic [Re: A12] #1570859
02/01/14 12:08 AM
02/01/14 12:08 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I know the reason for marking the valve covers is there is a difference with the engines that can't be spotted at the time of installation into the body or onto a K-frame, as noted the different carb for A/C and sometimes a different ignition timing for a 4-speed or automatic and there is something else that I can't think of?? (auto vs manual/3-spd/4spd?)
Re: '69 440 Valve Cover marking - See Pic [Re: RoadRunnerJD] #1570860
02/01/14 12:10 AM
02/01/14 12:10 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
an A12 4-speed would have 949 on the right valve cover and 950 for the automatic.
Re: '69 440 Valve Cover marking - See Pic [Re: A12] #1570861
02/01/14 01:53 AM
02/01/14 01:53 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Great thread guys. Does anyone have an original photo of the 949 A12 is describing?
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: '69 440 Valve Cover marking - See Pic [Re: A12] #1570862
02/01/14 02:02 AM
02/01/14 02:02 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Only LR cars had the engine assembly number on the tag. The car is a Charger so it's not from the LR plant so the assembly number won't be on the tag.
Seeking:
Re: '69 440 Valve Cover marking - See Pic [Re: 69CoronetRT] #1570863
02/01/14 01:24 PM
02/01/14 01:24 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Great post. I've saved all the photos and discussions for later reference.
Re: '69 440 Valve Cover marking - See Pic [Re: FJ5_Fish] #1570864
02/01/14 01:31 PM
02/01/14 01:31 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The 3 digit engine number is the last 3 numbers of the part number for that Engine Assembly. On the other side....an automatic trans equipped car would get either a 5, a 25 or a 125 depending on year etc. This number is based on the Engineering number for the Kick-down linkage. That is why standard transmission cars have a "0" on the v/cover....no kick-down linkage. I have a bunch of pics of various cars...I'll look for them. I have not seen these numbers on some low-mile, original cars....it seems not all had these markings....they were probably identified by different means...such as paper tags etc.
Very cool!! thanks for the clarification
Ron
Re: '69 440 Valve Cover marking - See Pic [Re: RJS] #1570865
02/01/14 06:20 PM
02/01/14 06:20 PM
Warrenton, VA
Warrenton, VA
Does a 5 mean that the kickdown is the same on an A12. As a 440-4?
Re: '69 440 Valve Cover marking - See Pic [Re: RoadRunnerJD] #1570866
02/02/14 07:29 AM
02/02/14 07:29 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Don't know John because they were deleting the 383 kickdown rod (p/n 2843797) and replacing it with a kickdown rod p/n 2951495 therefore the 5 on the driver's side and kickdown side valve cover of the engine. Don't know what that part number (2951495) is listed for normally?
Re: '69 440 Valve Cover marking - See Pic [Re: A12] #1570867
02/02/14 06:48 PM
02/02/14 06:48 PM
Warrenton, VA
Warrenton, VA
Just wondering because there is a 5 on both the 5600 mile survivor Bee and the 440-4 in this post. I'm not into reproducing those markings on mine but I regret not looking at my original valve covers more closely before I stripped them.
Re: '69 440 Valve Cover marking - See Pic [Re: RoadRunnerJD] #1570868
02/03/14 12:54 PM
02/03/14 12:54 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
The "5" denotes that the engine is for an automatic trans....regardless of engine type. The engine part number would dictate the actual linkage that is to be installed. And yes - the A12 engines had there own unique 3 digit engine numbers....which do not show up in GG's white books. A common A12 resto mistake is to put the b/cast sheet number on the valve cover.
Re: '69 440 Valve Cover marking - See Pic [Re: FJ5_Fish] #1570869
02/03/14 05:21 PM
02/03/14 05:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The "5" denotes that the engine is for an automatic trans....regardless of engine type. The engine part number would dictate the actual linkage that is to be installed. And yes - the A12 engines had there own unique 3 digit engine numbers....which do not show up in GG's white books. A common A12 resto mistake is to put the b/cast sheet 383 number on the valve cover.
Re: '69 440 Valve Cover marking - See Pic [Re: A12] #1570870
02/03/14 08:08 PM
02/03/14 08:08 PM
Phoenix, AZ
Phoenix, AZ
I definitely learned a lot - and real glad I saved those pictures before striping the covers.
Re: '69 440 Valve Cover marking - See Pic [Re: FJ5_Fish] #1570871
02/03/14 08:21 PM
02/03/14 08:21 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Which, as Dan said above, makes sense. So what is the code for a manual transmission and how does that relate?
Seeking:
Page 2 of 3 1 2 3
