Re: Interesting factroy tach dash bezel
[Re: hp383]
#1569030
01/26/14 05:53 PM
01/26/14 05:53 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
kool.. I had friends that bought a new big Dodge truck for their lumber yard. I never was in it to verify what the dash looked like..
I am truckless..
[Re: hp383]
#1569033
01/26/14 07:36 PM
01/26/14 07:36 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Good luck. That set up is rarer than hen's teeth.
Is it indeed from the Medium Duty 400-700 series trucks?
It is from d or w series up to 800 series. I have owned, sold from new a lot of those trucks and I don't ever recall seeing a tachometer. C series had them commonly and they were all cable driven off the distributor. I am sure it could of been an option, but I never have seen them.
[Re: franks lil red]
#1569042
01/27/14 05:34 PM
01/27/14 05:34 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Its still a 6000rpm tach.
The others use a single digit * 1000
this one uses a double digit * 100
the Medium Duty trucks would typically have had the 318 or maybe an industrial 413 platform.
If it was a diesel tach, it wouldn't use the same wiring as a gas (as seen on the back side)
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
#1569043
01/27/14 09:05 PM
01/27/14 09:05 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
why does the big tach read *100 where as the others are *1000 maybe the big one is a diesel.
What Diesel was used in the 400 and bigger trucks though? We think its from a car or something.
