Interesting factroy tach dash bezel #1569027
01/26/14 05:46 PM
01/26/14 05:46 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Saw some pictures of what is reported as the dash bezel from a 400 to 700 series Dodge truck. Said to have been used throughout the 70's in the bigger trucks.
If this is the case, I will be scouting for these. I think its a nice looking piece.
I personally have never seen the inside of the heavy duty trucks, so I dont know.
My thought was if its not from the HD trucks, maybe another Mopar in dash application, and thats why the wiring looks to be plug and play.
Re: Interesting factroy tach dash bezel [Re: hp383] #1569028
01/26/14 05:46 PM
01/26/14 05:46 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Re: Interesting factroy tach dash bezel [Re: hp383] #1569029
01/26/14 05:48 PM
01/26/14 05:48 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Interesting factroy tach dash bezel [Re: hp383] #1569030
01/26/14 05:53 PM
01/26/14 05:53 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
kool.. I had friends that bought a new big Dodge truck for their lumber yard. I never was in it to verify what the dash looked like..
I am truckless..
Re: Interesting factroy tach dash bezel [Re: hp383] #1569031
01/26/14 06:04 PM
01/26/14 06:04 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Good luck. That set up is rarer than hen's teeth.
Re: Interesting factroy tach dash bezel [Re: NITROUSN] #1569032
01/26/14 06:22 PM
01/26/14 06:22 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Is it indeed from the Medium Duty 400-700 series trucks?
Re: Interesting factroy tach dash bezel [Re: hp383] #1569033
01/26/14 07:36 PM
01/26/14 07:36 PM
N
N
It is from d or w series up to 800 series. I have owned, sold from new a lot of those trucks and I don't ever recall seeing a tachometer. C series had them commonly and they were all cable driven off the distributor. I am sure it could of been an option, but I never have seen them.
Re: Interesting factroy tach dash bezel [Re: NITROUSN] #1569034
01/26/14 07:46 PM
01/26/14 07:46 PM
N
N
Here is a pic of a factory 1978 dodge W-400 tach.
Re: Interesting factroy tach dash bezel [Re: hp383] #1569035
01/27/14 12:22 AM
01/27/14 12:22 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'm surprised it goes to 6000.
Sheldon
Re: Interesting factroy tach dash bezel [Re: RUNCHARGER] #1569036
01/27/14 01:11 AM
01/27/14 01:11 AM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
Had a 79 Lil Red Express had a Sun tach. in that spot not factory looked cool there
Re: Interesting factroy tach dash bezel [Re: BlwnCrcab] #1569037
01/27/14 04:48 AM
01/27/14 04:48 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What Jamie is wanting to know is is the Larger tach setup he posted Factory for the 400up. It was stated it was only in the 400up trucks. I assume we've All seen the Smaller one that nitrousin posted. I've had a few myself
Re: Interesting factroy tach dash bezel [Re: 76dodgeboy] #1569038
01/27/14 02:02 PM
01/27/14 02:02 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Of course this isn't factory, but I couldn't afford the high dollar prices people wanted for their factory tachs. I went out and got an AutoMeter tach. The only reason I pick up this one is because the hole was already there for a trans cooler gage (broken, and not working) and this slid right in. Works great, not hard to read at a glance, and the needle is the same color as the rest. Just an option.
Re: Interesting factroy tach dash bezel [Re: 76dodgeboy] #1569039
01/27/14 04:07 PM
01/27/14 04:07 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Exactly.
I have seen, and had, the factory small tach, but never seen the large diameter tach as a factory installation.
The tack had a pentastar stamped just under the U bracket, and the part number looks Mopar.
I just want to know if the Medium Duty trucks have been hiding a really cool factory truck dash.
Re: Interesting factroy tach dash bezel [Re: hp383] #1569040
01/27/14 04:31 PM
01/27/14 04:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
High dollar? Sold mine for $60 condition unknown
Re: Interesting factroy tach dash bezel [Re: 76dodgeboy] #1569041
01/27/14 04:57 PM
01/27/14 04:57 PM
usa
franks lil red Offline
usa
why does the big tach read *100 where as the others are *1000 maybe the big one is a diesel.
Re: Interesting factroy tach dash bezel [Re: franks lil red] #1569042
01/27/14 05:34 PM
01/27/14 05:34 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Its still a 6000rpm tach.
The others use a single digit * 1000
this one uses a double digit * 100
the Medium Duty trucks would typically have had the 318 or maybe an industrial 413 platform.
If it was a diesel tach, it wouldn't use the same wiring as a gas (as seen on the back side)
Re: Interesting factroy tach dash bezel [Re: franks lil red] #1569043
01/27/14 09:05 PM
01/27/14 09:05 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What Diesel was used in the 400 and bigger trucks though? We think its from a car or something.
Re: Interesting factroy tach dash bezel [Re: hp383] #1569044
01/27/14 09:29 PM
01/27/14 09:29 PM
N
N
The bezel is 77 or newer.
Dodge quit making D series 500-800 trucks in 77 or 78.
It sure looks factory from the hole to the wires and the tachometer itself.
Maybe exported truck?
Re: Interesting factroy tach dash bezel [Re: NITROUSN] #1569045
01/27/14 10:09 PM
01/27/14 10:09 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Wouldn't that bezel fit the 75 through 80 dodge trucks?
What makes it a 77 or newer?
Re: Interesting factroy tach dash bezel [Re: hp383] #1569046
01/27/14 11:09 PM
01/27/14 11:09 PM
N
N
Silver color. 76 on back was black. 77 on up was silver.
