505 Stroker Indy EZ-1 which cam and valvespring #1568040
01/24/14 04:59 PM
01/24/14 04:59 PM
Milwaukee, WI
moparjimbo Offline OP
Milwaukee, WI
So I picked up an already built 505 off here. Its a 440 block, Eagle stroker kit, has Indy EZ-1 Max Wedge port heads with I am told are as they come from Indy springs wise, and for a cam it has the old Mopar .590 in it 4 degrees retarded.
Its going in a 67 Fury Police Pursuit car I picked up last year (the block is actually a 67 within a few days of the cars build date) and I want to have a hassle free large amount of street miles drivable car as well as occasional strip use. I have much faster cars for strip use already, this is my "cruiser" lol so I am willing to leave a fair amount of peak power (but not too much) on the table in exchange for a fairly decent idle, fairly low maintenance rocker adjustment and valvespring life wise, enough vacuum for my power brakes, etc. I recently went with a street/strip converter in the thing like a 2500-3000 or so stall, a mildly built 727 from Keith Long, and I went with the factory original 3:23 gears and a nice sure grip setup from Dr. Diff. so I do not want to change any of that.
So what I was thinking was I went out and got the dual plane indy manifold already and will open that up to the MW ports, and I was going to go with an 850 or 950 4150 carb. I was looking at going with a much more streetable and lower maintenance cam either a hydraulic or hydraulic roller with around 250 duration at 50 like the XE295HL Comp Cams hydraulic (251/257 duration at 50, .564 lift) since everything I am seeing points to the .590 Mopar being too much duration for me, much bigger stall requirements, and frequent lash adjustment. As far as the springs I have no idea - all I seem to find is that the heads have springs "good for .600 lift" in em. Would these be decent for a hydraulic or hydraulic roller in the mid-high 500 lift range? Anyone know what specific springs these heads come with?
Looking for input basically what do you guys think or recommend?
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: moparjimbo] #1568041
01/24/14 05:04 PM
01/24/14 05:04 PM
Milwaukee, WI
Milwaukee, WI
Also, I was going to go with the TTI 1-3/4 primary C body headers and 3" exhaust. Compression works out to around 11.5 to 1.
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: moparjimbo] #1568042
01/24/14 07:25 PM
01/24/14 07:25 PM
AndyF Offline
AndyF  Offline
A small street roller cam is probably what you want. Take a look at the cam specs for the Chevy 502 engine and you'll be surprised at how small it is. That is a super popular engine for the street rod crowd and it is tiny compared to the cams that people on here tend to recommend.
The MP .590 is way too big for a street driven Fury with high rear end gears. The MP .528 would be very smooth and have a lot of power in that 505.
Re: 505 Stroker Indy EZ-1 which cam and valvespring *DELETED* *DELETED* [Re: AndyF] #1568043
01/24/14 07:38 PM
01/24/14 07:38 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Post deleted by Mopar Guy
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: Mopar Guy] #1568044
01/24/14 08:25 PM
01/24/14 08:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Those EZ-1 heads come with Comp 911 springs. You can look at Comp's website to see the spec on them.
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: moparjimbo] #1568045
01/25/14 02:08 AM
01/25/14 02:08 AM
Cab_Burge Online work
Cab_Burge  Online Work
Advance the cam(all o fthem ) so the intake lobes are 3 to 6 degrees advanced That C body wil like the increased bottom end
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: Stanton] #1568046
01/25/14 08:05 PM
01/25/14 08:05 PM
Milwaukee, WI
Milwaukee, WI
Hrmm those are a single spring with damper. What Ive got by eye is a double spring with damper...
With the new hydraulic rollers they can just be used as is right? No need to bush lifter bores or any of that like a solid roller? No super high spring rates?
Like I said Im leaning towards a regular ole hydraulic do to friendly spring rates, cost, ease of maintenance, etc. If the hydraulic rollers are better and still streetable springs and no need for machine work I would be in...
Keep the recommendations coming!
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: moparjimbo] #1568047
01/25/14 08:22 PM
01/25/14 08:22 PM
MN
W
Willie68coronet Offline
W
MN
I bought my EZ heads direct from Indy at a car show and my heads have comp 928 dual springs with damper rated to .650 lift.
I had a shop look the heads over and they tested the springs at 160 pounds seated (1.925" installed height) 335 pounds 500 lift and 380 pounds 620 lift and coil bind at 1.150 (775 lift).
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: moparjimbo] #1568048
01/25/14 10:35 PM
01/25/14 10:35 PM
AndyF Offline
AndyF  Offline
If you're going to go with a hyd roller cam then you should ditch the Indy springs and install some beehives.
I have a set of new Comp hyd roller lifters that I'll make you a deal on. Shoot me a PM if you're interested. I probably have some other parts to make that combo work for you. I've been using EZ heads for a long time.
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: AndyF] #1568049
01/26/14 05:09 PM
01/26/14 05:09 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
If you diside to use any roller cam chose lifter´s whit care and there are some great topics on it in this forum so nobody try to sell you any bad once some that makes cams try to sell crappy lifters
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: moparjimbo] #1568050
01/26/14 05:49 PM
01/26/14 05:49 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If you go hydraulic roller, the valve springs will need to match the cam pretty close. If you have the $$$ the behive springs are good, but make sure they can handle your valve lift. Higher ratio rocker arms may increase lift beyond the "recommend" valve spring.
On my 505" stroker with the Comp XR286 cam, I used ISKY 8005A valve springs with Comp 748-16 retainers, and it seems to be running good with that spring (RPM Limiter set to 6,000 RPM.)
Re: 505 Stroker Indy EZ-1 which cam and valvespring [Re: moparjimbo] #1568051
01/26/14 05:54 PM
01/26/14 05:54 PM
SoCal
Brian Hafliger Offline
SoCal
Are you leaving it at that compression? E85 or regular pump gas?
Brian Hafliger
