Re: Foot braking on a .500 Pro Tree w/3400lb car
[Re: nss guy]
#1567790
01/24/14 09:26 AM
01/24/14 09:26 AM
Posts: 204 Indiana
MFR426
Indiana
Jim, For what it's worth, we did some Super Street racing a few years ago with the Dodge (Ladder bar) and then the Plymouth (CalTracs). My brother and nephew's car is run all the time in S/ST and we like to go with them. The best this old man could do was in the high 20's and mostly 30's for reaction times with the Dodge. The Plymouth does not react as fast and Brian was mainly in the 40's. Our cars do not 60 foot good so you may do much better but we could give those electronic cars a scare once in awhile! The best I did was third round at an NHRA Divisional and I did win one round at a National event. I think you will not have any problems since everyone else will be in the same boat. Assume you are talking about the one series that is doing NSS with the .500 Pro tree. Good Luck this year! Mfr426 ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MFR426]
#1567791
01/24/14 10:59 AM
01/24/14 10:59 AM
Posts: 1,178 Indy
FlyFish
Indy
My car worked really well with a .500 pro tree. We had 7.0 and 11.0 indexes out here a few years back, and as long as I rolled my car in a little deep (not putting out the top bulb) I would get lights in the 20's foot braking.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: nss guy]
#1567793
01/24/14 01:47 PM
01/24/14 01:47 PM
Posts: 1,301 Penna
70satelliteguy
Penna
In my experience if your car leaves hard you will find yourself red lighting on a 500 pro tree quite often especially if you run a brake! Foot braking should help some but could still be a problem if you stage too deep ![](/ubbthreads/images/graemlins/thumbs.gif) As an example Pro stock cars and bikes would red light every time if the ran a 500 tree instead of a 400 tree Mike ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 70satelliteguy]
#1567794
01/24/14 01:56 PM
01/24/14 01:56 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Well IF Pro Stock cars and bikes ran on a .400 tree they would still be way red. A National Event pro tree is .370 not .400. It was done specifically for those two classes. But everyone running a .400 pro tree at a national gets the same .370 tree. Meaning s/g and s/c also use this tree at national events.
[Re: JLaSalle]
#1567795
01/24/14 02:16 PM
01/24/14 02:16 PM
Quicktree
if you can cut a light on a regular .5 tree it shouldn't be a problem you just have to be ready.
Little bit of a difference though switching from full tree to pro tree due to the fact that your not anticipating the bulb.I saw about .03 slower light going from full tree to pro tree.You don't think your anticipating on a full tree, but you are.
To the op, I would say crank up your launch rpm if possible and BE READY.
a good racer doesn't anticipate the tree. my lights were exactly the same going from regular to pro tree ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Quicktree]
#1567796
01/24/14 03:02 PM
01/24/14 03:02 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
I always watched just the bottom bulb on a Sportsman tree, so a .500 Pro tree was exactly the same for me. I was consistently .480 red on it. ![](/ubbthreads/images/graemlins/frowwn.gif)
[Re: nss guy]
#1567797
01/24/14 04:11 PM
01/24/14 04:11 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
What's that like? Any advantage for a transbrake car same weight have over a foot brake car on a .500 Pro Tree if any? Just curious
My Duster and me could cut .0103 to .620 on any given day foot brake in Pro on the sportsman tree In all seriousenes(SP?), the driver has to control the car, with a trans brake button or foot braking, correct? I use to run a car in Division 7 when we used a .400 Pro Tree in both Pro bracket and S/ST That car 1970 Duster(ladder bar rear suspension, stock front suspension with a lot of front travel) would react better foot braking than it would with a older Trans Brake The rear suspension can and will affect the reation times, so the car, driver and the front and rear suspension have a lot to do with the results ![](/ubbthreads/images/graemlins/Twocents.gif) ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: JLaSalle]
#1567798
01/24/14 04:11 PM
01/24/14 04:11 PM
Al_Alguire
Las Vegas
Well just fyi 67rt is about as good a racer as you will find out there. I have found pretty much the same as he has which is why I struggle on the full tree racing with no box.
[Re: nss guy]
#1567799
01/24/14 04:28 PM
01/24/14 04:28 PM
Posts: 682 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
Yea, Jim we are screwed next to transbrake guys. Looking at just the bottom bulb than going to a .500 pro is a different animal. We can do it, just not as consistant as the tranny brake guys will.
Casey
[Re: Al_Alguire]
#1567801
01/24/14 07:27 PM
01/24/14 07:27 PM
Quicktree
thats because you anticipate I bet it's hard to go from a top bulb to bottom bulb not doing it on a regular basis. it was easier for me to go to top bulb from bottom. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Whompin_Wedge]
#1567802
01/24/14 08:19 PM
01/24/14 08:19 PM
Al_Alguire
Las Vegas
I know why I struggle. Even with the blinder you can see the tree coming down. To be honest I focus on pro tree stuff not much of anything else.
[Re: Al_Alguire]
#1567803
01/24/14 08:39 PM
01/24/14 08:39 PM
Quicktree
I understand, that is the same problem everyone has. I considered myself a very good footbrake racer back before delay boxes were thought about. and became a good box racer once I switched. now going back to the bottom bulb was good at times but not as consistent as I was. it just takes seat time to overcome either. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: ajcasini]
#1567804
01/24/14 08:59 PM
01/24/14 08:59 PM
Whompin_Wedge
COLUMBUS, OH
If this is in reference to the BGRCS races the NSS class is footbrake only.
.... oh really.... I did not know this.
Casey
[Re: dvw]
#1567806
01/24/14 11:47 PM
01/24/14 11:47 PM
Posts: 1,443 central ohio
nss guy
central ohio
Casey
I raced both of you. There's a lot of trans brake cars I'd rather face Doug
Not so much the transbrake deal, it's the pro tree that's staggered for different dial ins
Lot's of good advice: roll in a little deep, BE Ready.
The car in the other lane dial is 2 tenth's slower, you're on the converter ready for the "flash" to leave...... oops that was his flash not yours and you flinched.
How many people race on a staggered pro tree?
Al? Quicktree? 67/rt, mfr?
