Foot braking on a .500 Pro Tree w/3400lb car #1567787
01/24/14 12:22 AM
01/24/14 12:22 AM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
What's that like?
Any advantage for a transbrake car same weight have over a foot brake car on a .500 Pro Tree if any?
Just curious
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: nss guy] #1567788
01/24/14 08:42 AM
01/24/14 08:42 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
How quick will the car react...Its more Hp/torque dependant, than trans brake dependant. Large stroke big block won't have a problem on either.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Dragula] #1567789
01/24/14 09:20 AM
01/24/14 09:20 AM
Q
Quicktree Offline
Quicktree  Offline
Q
if you can cut a light on a regular .5 tree it shouldn't be a problem you just have to be ready.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: nss guy] #1567790
01/24/14 09:26 AM
01/24/14 09:26 AM
Indiana
MFR426 Offline
MFR426  Offline
Indiana
Jim,
For what it's worth, we did some Super Street racing a few years ago with the Dodge (Ladder bar) and then the Plymouth (CalTracs). My brother and nephew's car is run all the time in S/ST and we like to go with them. The best this old man could do was in the high 20's and mostly 30's for reaction times with the Dodge. The Plymouth does not react as fast and Brian was mainly in the 40's. Our cars do not 60 foot good so you may do much better but we could give those electronic cars a scare once in awhile! The best I did was third round at an NHRA Divisional and I did win one round at a National event. I think you will not have any problems since everyone else will be in the same boat. Assume you are talking about the one series that is doing NSS with the .500 Pro tree.
Good Luck this year!
Mfr426
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: MFR426] #1567791
01/24/14 10:59 AM
01/24/14 10:59 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
My car worked really well with a .500 pro tree. We had 7.0 and 11.0 indexes out here a few years back, and as long as I rolled my car in a little deep (not putting out the top bulb) I would get lights in the 20's foot braking.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Quicktree] #1567792
01/24/14 01:37 PM
01/24/14 01:37 PM
norcal
JLaSalle Offline
JLaSalle  Offline
norcal
Little bit of a difference though switching from full tree to pro tree due to the fact that your not anticipating the bulb.I saw about .03 slower light going from full tree to pro tree.You don't think your anticipating on a full tree, but you are.
To the op, I would say crank up your launch rpm if possible and BE READY.
1967 Coronet R/T
9.83 134mph. 470 cid st.6 heads
10x pro et track champion
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: nss guy] #1567793
01/24/14 01:47 PM
01/24/14 01:47 PM
Penna
70satelliteguy Offline
Penna
In my experience if your car leaves hard you will find yourself red lighting on a 500 pro tree quite often especially if you run a brake!
Foot braking should help some but could still be a problem if you stage too deep As an example Pro stock cars and bikes would red light every time if the ran a 500 tree instead of a 400 tree
Mike
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: 70satelliteguy] #1567794
01/24/14 01:56 PM
01/24/14 01:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well IF Pro Stock cars and bikes ran on a .400 tree they would still be way red. A National Event pro tree is .370 not .400. It was done specifically for those two classes. But everyone running a .400 pro tree at a national gets the same .370 tree. Meaning s/g and s/c also use this tree at national events.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: JLaSalle] #1567795
01/24/14 02:16 PM
01/24/14 02:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
a good racer doesn't anticipate the tree. my lights were exactly the same going from regular to pro tree
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Quicktree] #1567796
01/24/14 03:02 PM
01/24/14 03:02 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I always watched just the bottom bulb on a Sportsman tree, so a .500 Pro tree was exactly the same for me.
I was consistently .480 red on it.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: nss guy] #1567797
01/24/14 04:11 PM
01/24/14 04:11 PM
What's that like?
Just curious
My Duster and me could cut .0103 to .620 on any given day foot brake in Pro on the sportsman tree In all seriousenes(SP?), the driver has to control the car, with a trans brake button or foot braking, correct? I use to run a car in Division 7 when we used a .400 Pro Tree in both Pro bracket and S/ST That car 1970 Duster(ladder bar rear suspension, stock front suspension with a lot of front travel) would react better foot braking than it would with a older Trans Brake The rear suspension can and will affect the reation times, so the car, driver and the front and rear suspension have a lot to do with the results
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: JLaSalle] #1567798
01/24/14 04:11 PM
01/24/14 04:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well just fyi 67rt is about as good a racer as you will find out there. I have found pretty much the same as he has which is why I struggle on the full tree racing with no box.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: nss guy] #1567799
01/24/14 04:28 PM
01/24/14 04:28 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
What's that like?
Just curious
Yea, Jim we are screwed next to transbrake guys. Looking at just the bottom bulb than going to a .500 pro is a different animal. We can do it, just not as consistant as the tranny brake guys will.
Casey
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Whompin_Wedge] #1567800
01/24/14 04:31 PM
01/24/14 04:31 PM
PA
ajcasini Offline
ajcasini  Offline
PA
If this is in reference to the BGRCS races the NSS class is footbrake only.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Al_Alguire] #1567801
01/24/14 07:27 PM
01/24/14 07:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats because you anticipate I bet it's hard to go from a top bulb to bottom bulb not doing it on a regular basis. it was easier for me to go to top bulb from bottom.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Whompin_Wedge] #1567802
01/24/14 08:19 PM
01/24/14 08:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I know why I struggle. Even with the blinder you can see the tree coming down. To be honest I focus on pro tree stuff not much of anything else.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Al_Alguire] #1567803
01/24/14 08:39 PM
01/24/14 08:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I understand, that is the same problem everyone has. I considered myself a very good footbrake racer back before delay boxes were thought about. and became a good box racer once I switched. now going back to the bottom bulb was good at times but not as consistent as I was. it just takes seat time to overcome either.
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: ajcasini] #1567804
01/24/14 08:59 PM
01/24/14 08:59 PM
COLUMBUS, OH
W
W
COLUMBUS, OH
.... oh really.... I did not know this.
Casey
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: Whompin_Wedge] #1567805
01/24/14 09:12 PM
01/24/14 09:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What's that like?
Just curious
Casey
I raced both of you. There's a lot of trans brake cars I'd rather face
Doug
Re: Foot braking on a .500 Pro Tree w/3400lb car [Re: dvw] #1567806
01/24/14 11:47 PM
01/24/14 11:47 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
What's that like?
Just curious
Casey
Doug
Not so much the transbrake deal, it's the pro tree that's staggered for different dial ins
Lot's of good advice: roll in a little deep, BE Ready.
The car in the other lane dial is 2 tenth's slower, you're on the converter ready for the "flash" to leave...... oops that was his flash not yours and you flinched.
How many people race on a staggered pro tree?
Al? Quicktree? 67/rt, mfr?
