Stock K Frame Weight Loss? #1567372
01/23/14 12:13 AM
01/23/14 12:13 AM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
How many pounds can I remove from my K-Frame? It weighs 32.2 pounds at the moment.
[img] [/img]
Re: Stock K Frame Weight Loss? [Re: clonestocker] #1567373
01/23/14 12:48 AM
01/23/14 12:48 AM
As much as you want Are you feeling lucky All kidding aside, I have seen some of them drilled full of large holes, front, back, top and bottom I had a CAP tubular K member for stock steering and torsion bars for the early,1963 to 1966 A bodys, it weighed 23 lbs, my stock one weighed 25 lbs. I'm sure the later A bodys are a little bit heavier, there bigger (I have both)
Re: Stock K Frame Weight Loss? [Re: Cab_Burge] #1567374
01/23/14 12:54 AM
01/23/14 12:54 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I cut all the lip area and welded mine up prolly about 3-5 lbs removed maybe more I hadn't weighed it yet
Re: Stock K Frame Weight Loss? [Re: Cheatham] #1567375
01/23/14 01:50 AM
01/23/14 01:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Cut the flanges, engine mounts, extra bracing for the steering gear and the center leaving about 2". Weld it all up. Patch the holes to look good. Add a tube to brace the steering mount. Lose 18 lbs.
Doug
Re: Stock K Frame Weight Loss? [Re: dvw] #1567376
01/23/14 01:52 AM
01/23/14 01:52 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
welded up
Re: Stock K Frame Weight Loss? [Re: dvw] #1567377
01/23/14 01:53 AM
01/23/14 01:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bottom
Re: Stock K Frame Weight Loss? [Re: dvw] #1567378
01/23/14 01:47 PM
01/23/14 01:47 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I like how you radiused the inside corners, very nice.
Boffin Emeritus
Re: Stock K Frame Weight Loss? [Re: polyspheric] #1567379
01/23/14 04:16 PM
01/23/14 04:16 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I'm doing the same thing to mine.... I didn't weigh it before... I don't care how much I actually loose. I just like the fact that it will be lighter!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Stock K Frame Weight Loss? [Re: dvw] #1567380
01/26/14 01:46 AM
01/26/14 01:46 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Is that body putty?
Be interesting if it flexes enough over time to flake and be a structural load indicator.
It looks nice.
Re: Stock K Frame Weight Loss? [Re: polyspheric] #1567381
01/26/14 08:39 PM
01/26/14 08:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Is that body putty?
It looks nice.
The corners were easy. I hole sawed the K before it was cut out. Yes it's bondoed. This is the second one done this way. The other one is 10 tears old, no cracks.
Doug
Re: Stock K Frame Weight Loss? [Re: clonestocker] #1567382
01/27/14 12:23 AM
01/27/14 12:23 AM
Australia
P
Project kickin A Offline
P
Australia
I brought mine off a member here all done, saved 12lb over my old junk
Re: Stock K Frame Weight Loss? [Re: Project kickin A] #1567383
01/27/14 12:26 AM
01/27/14 12:26 AM
Australia
P
P
Australia
between that and the QA1 & Aerospace compoents Iv shaved 138lbs off the front of the car.
